587,065 active members*
3,885 visitors online*
Page 2 of 2 12
Results 21 to 29 of 29
  1. #21
    Dec 2009
    521
    Re: Torq Cut 22 - Sound Check
    Quote Originally Posted by DarkStarMedia View Post
    Just as an update... I am highly considering pulling my z axis and doing a refresh. I had a bit of an accident (tossed a part via a facemill) and I now have a bit of a tick in my spindle at higher rpms. I was running it a bit and I think my axis are a bit louder than your guys. I got some estimates on rebuilding the ballscrews and they were in the $1-2k each range. I might just try to do end bearings because I have noise but no real backlash.
    Richard
    Bummer Richard,
    You might post a new thread, so that MACTEC chimes in. I seem to remember his concern about ball screw alignment on the Z axis.
    Sounds like its going to be quite a job. Keep us posted on your progress.
    Take pics and video if you can for the rest of us in case we have to "cross that bridge"
    Marty
  2. #22
    Oct 2005
    48
    Richard
    My X axis was noisy but no backlash before I replaced the bearings. The ball screw is easy to tear down, clean and reassemble yourself. However if you are fitting new balls I could see the cost paying someone $1000 or so being justifiable.
  3. #23
    Sep 2009
    135
    I paid about $460 to have my ball screw service.
    Sent from my SM-G955U using Tapatalk
  4. #24
    Dec 2009
    521
    Quote Originally Posted by cooperjm View Post
    Who did your ballscrew service and what did they do to it and why did you send it in?
    Marty
  5. #25
    Sep 2009
    135
    The wiper on the end of the nut was broken. They replaced the wiper and installed larger balls to take out backlash.
    I sent the screw to Rand Industries, a part of Rockford ball screw.
    I do not remember why I was looking around in there when I found the broken wiper. I also found the oil distribution block was corroded baldy. I replaced the block and the meters while I had it apart.
  6. #26
    Mar 2016
    Hi, I know its been a while since the last post but I'm having a similar noise along my Y axes and was wondering how hard was it to change out the thrust bearings? Do you have to fully remove the shaft or can you just slide the bearings off?
  7. #27
    Sep 2009
    135
    If I remember correctly you're going to have to at least Slide the screw out far enough to get the bearings off the end.
  8. #28
    Mar 2016
    Thanks for the reply. Are the bearings pressed on and do you need to indicate the shaft after reinstall?
  9. #29
    Sep 2009
    135
    Bearings are not pressed. Not sure about indicating it
Page 2 of 2 12
  1. 4th axis sound check
    By AVRnj in forum Tormach Personal CNC Mill
    Last Post: 06-22-2015, 01:27 AM
  2. Does this sound right?
    By mredican in forum Mechanical Calculations/Engineering Design
    Last Post: 12-08-2009, 06:07 PM
  3. Torq-Cut 22 Shutdown! Please check this if you know these machines
    By RedGTZ in forum Bridgeport / Hardinge Mills
    Last Post: 02-20-2008, 02:22 PM
  4. Replies: 3
    Last Post: 01-19-2007, 02:59 PM
  5. does this set up sound right?
    By replicapro in forum Benchtop Machines
    Last Post: 06-10-2004, 10:43 PM
