586,080 active members*
3,651 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > Download Ladder Fanuc 15-M by Fanuc Ladder III software
Results 1 to 8 of 8
    Feb 2016
    17
    Hi!
    I really need for your helps about Ladder Fanuc!
    I want to download Ladder of Fanuc 15M to PC by Fanuc Ladder III, but I have some problem :
    - I connected and set up the communication of FAPT III
    . Setting Port = Com 3
    . Baudrate = 4800 ( The same PMC I/O)
    . Parity = Even
    . Stop bit = 2
    - Set Keep relay
    K17.1 = 1 (01000110)
    - Select PCPRM - I/O - Channel I/O = 0 (cannot change)
    - Select Output - P-G (FAPT Ladder) - Execute
    - In the FAPT,
    . Tool - load from PMC - I/O by monit online - Connect and wait a few seconds the FAPT alarm disconnect.
    . When I select I/O by "I/O" key operation - ladder - Finish ( I see the monitor of CNC machine notices output complete but The FAPT software still executing and nothing happens. When i cancel, the FAPT notices
    " MCARD file not found ".
    Apr 2009
    1379
    Re: Download Ladder Fanuc 15-M by Fanuc Ladder III software
    The 15A controls had no PCMCIA card; the 15B series did, but no user files such as the LADDER can be stored on it.
    Fanuc Ladder III doesn't support the 15MA controller. You need A08B-9201-J501#EN (PMC-N)
    Feb 2016
    17
    Quote Originally Posted by memoryman View Post
    Quote Originally Posted by drdos View Post
    Thanks you. I really appreciate for your help.
    Mr Drdos, your mean is update lasted Fanuc Ladder III right? Which version is A08B-9201-J501?
    Now im using the version 5.7.
    Feb 2016
    17
    Can you guide me or give me the software to load ladder?
    It was an old DOS program. I haven't used it in years, I don't know if Fanuc even still sells it. You may try searching the net. sorry
    Feb 2016
    17
    OK. I found it and instralled it in win xp but i don't know how to use it. Haha....
    Thanks a lot
    You cannot use Faptladder 3 for this. Are you still in need of help?
  1. Replies: 12
    Last Post: 05-09-2023, 09:01 AM
  2. Fanuc Ladder software Save to a memory card
    By martingandara in forum Fanuc
    Last Post: 06-27-2017, 12:34 PM
  3. Fanuc Ladder III software
    By iNUC in forum Fanuc
    Last Post: 02-16-2013, 01:59 AM
  4. Fanuc Ladder III software issue
    By Walz in forum Fanuc
    Last Post: 05-09-2012, 12:45 PM
  5. fanuc om-a ladder
    By rathi_vk in forum Fanuc
    Last Post: 06-12-2009, 03:34 AM
