586,974 active members*
3,089 visitors online*
Thread: cut ramps
Results 1 to 11 of 11
    Mar 2006
    23
    cut ramps
    hi was wondering how to cut ramps into a flange i drew in autocad. the ramps need to be the three outer wings of the circle. its a lid for a twist lock flange made of acrylic. when you twist it down the ramps put pressure on an oring and make a water tight seal. im pretty green at acad still. ive extruded it out to the size it needs to be - .25" but cant figure out how to ramp it. i'll attach the dxf so you can see it and a picture of what i am trying to accomplish.
    Attached Files Attached Files
    You want to solid model it? In 2007, you can loft it. In older versions, I'd model it with a mesh and download a mesh to solid lisp from the web to convert it to a solid.
    Mar 2006
    23
    well i guess i should say that i am very green at acad. maybe you can walk me thru it. i have 07 version.
    OK, lofting doesn't work. Use the helix command to draw the top 2 edges of the ramp. Set surftab to a high number (I used 100) and create a ruled surface using the helix's. Then download a Mesh to solid lisp to convert the Mesh to a solid. I used this one, but it didn't seem to work right. I had to keep hitting enter for it to finish. http://www.cadtutor.net/forum/showthread.php?t=1408
    A tabulated surface might be better. I attached a file with all 3 parts, helix, surface and solid for you to look at. It's very likely that this will be way over your head.
    There might be a better way, but I don't have time to play around with it any more.
    Mar 2006
    23
    thanks for looking at it ger, i appreciate your time. you are correct in that it is over my head but i will just have to wrap my head around it for awhile. i'll let you know how it goes.
    Mar 2006
    23
    ok so now i've draw it...what CAM software will cut it out? i have cambam and tried the ac2gc macro but they dont seem to work.. any suggestions?
    Mar 2006
    23
    how can i export this as an stl? gives the error of not being "in the positve xyz octant"
    Mar 2006
    23
    oops heres the file
    Here you go
    Mar 2006
    23
    Here you go
    thank you, but i guess i am just so thick skulled i still dont see how you did it. i enter the box command and set it to 0,0,0 but that only gets half the drawing inside the cube. so i still get that positve xyz octant error. i can export the solid from your attached file, though. thank you. what am i doing wrong with drawing the cube?
    You're not drawing it in the correct place. If you look at the drawing I posted from a top, side and front view, you'll see that one corner is at 0,0,0, and the other is in the positive direction of all the axis.
    You could also draw 3 construction lines through 0,0,0. One along the X, Y, and Z axis. From the top view, the part should be in the top right quadrant. From the front view, it should also be in the top right quadrant. And if you do a right side view, once again it should be in the top right quadrant.
    Let me know if you still don't get it, and I'll try to post some pics tomorrow.
