Hello, i think the mach 3 users can help me here. I was testing for the first time my DIY alum machining center and got this weird G-CODE toolpath at MACH.
As you can see at the right corner, there is a strange loop on the part, but the toolpath was supposed to look like this:
I use the MasterCAM 2017 with a post processor called Boss_Mach3, that is created by the users for the X versions of MCAM.
To use at MCAM 2017 we need to update for 2017 using the UpdateUtility.dll provided my Mastercam itself. I don't believe this affects anything.
The code is being generated without errors.
The strange loop thing on the part( I hope you guys can see it on the image) happens on this line of code:
It's a G2, when my machine goes into that line, if you take a close look at MACH 3 SCREEN IMAGE, you will be able
that the line itself happens like 10 or 20 times.
N5090
N5090
N5090... so many times. And my tool keeps spinning.
Does anyone knows what is happening? My coordinates are absolute, my IJ is working on relative coordinates.
