586,121 active members*
3,121 visitors online*
    Jan 2017
    4
    taig headstock rotation
    has anyone come up with a way to rotate the head stock 90 degrees? I was hoping there was a small right angle adapter but i cant find one. I know the Z column rotates but i still need to move in the vertical Z axis when the tool is horizontal. thank you!
    Jun 2011
    68
    Re: taig headstock rotation
    Here is the quick and painless way I did it when I was setting up my Taig's Vertical supports.
    Just turn the Dovetail mount for the headstock 90 degrees...
    hth,
    Stuart
    Feb 2007
    4553
    There are many tips and ideas on the Carter Tool Site.
    Pictures of Taig Lathe
    Patience and perseverance have a magical effect before which difficulties disappear and obstacles vanish.
    Jan 2017
    4
    thank you! I thought that may be the only way but was worried about the weight of the motor hanging off the end of it. I really enjoy nick carters website but there is so much info i tend to get lost in it. haha.
  1. Taig headstock falls
    By littleCNCjohn in forum Benchtop Machines
    Last Post: 08-30-2011, 01:43 PM
  2. MT1 into taig headstock
    By chris123 in forum Taig Mills / Lathes
    Last Post: 10-19-2010, 12:16 PM
  3. T-Slots on the taig headstock housing
    By surrealism in forum Taig Mills / Lathes
    Last Post: 07-02-2010, 09:15 PM
  4. Raising Taig headstock
    By MechanoMan in forum Taig Mills / Lathes
    Last Post: 04-14-2009, 10:29 PM
  5. Taig Headstock Improvements??
    By scubasteve_911 in forum Taig Mills / Lathes
    Last Post: 08-22-2007, 06:10 PM
