586,076 active members*
3,708 visitors online*
Results 1 to 10 of 10
    Jul 2004
    51
    limit switch triggered
    I keep getting a 'limit switch triggered' on the status readout and the emergency LED flashes on the diagnostics page with Mach2. All limit switches are OK. The Emergency switch is functional but doesn't set off the reset LED when pressed down . Any help is 'perciated.
    Jun 2004
    6618
    Re: limit switch triggered
    Mach 2???
    First if that is true, switch to Mach 3.
    Lee
    Jul 2004
    51
    Quote Originally Posted by LeeWay View Post
    Mach 2???
    Mach3 is now installed. Not getting a limit switch condition as before but the E stop switch still does not work. Motors are singing but no motion. PMDX-122 and Gecko drives seem to be working OK.
    Jun 2004
    6618
    Okay. Better.
    Under config, ports and pins, have you checked that the limits and estop is wired to the correct pins?
    Lee
    Sep 2017
    14
    If the motors are singing but not moving double check that you have the pins right for direction and step as you could have them swapped... and on limit switch are they wired for Normally open low input or high input?
    Jul 2004
    51
    Thanks guys. It'll take a little time reading Mach3 docs as it appears there are some changes. Thanks for the input and I'll let you know how things go asap.
    Mar 2007
    2083
    taken from the PMDX-122 manual
Name:	PMDX-122  Mach 3 config .jpg
    John
    Sep 2017
    14
    Quote Originally Posted by john-100 View Post
    John
    Yes so you ports and pins should look somewhat like this one ... the direction and step are swapped on the setup so it's not 2,3,4,5 but 3,2,5,4
    Mar 2007
    2083
    that matches the PMDX-122 rev D manual I looked at
    John
    Sep 2006
    245
    What does the wiring to the switches look like? Is it shielded? Mach lets you see the switch status, but sometimes it is also helpful to look at the signals with a scope or multimeter.
    Steve
  1. Limit Switch Triggered! IS NOT!!
    By Mr.Chips in forum Mach Software (ArtSoft software)
    Last Post: 05-13-2020, 12:18 PM
  2. Limit switch triggered
    By bohica in forum Charter Oak Automation Support Forum
    Last Post: 12-12-2015, 01:28 PM
  3. limit switch triggered
    By Claude Boudreau in forum Machines running Mach Software
    Last Post: 04-29-2012, 01:06 PM
  4. limit switch triggered issue
    By 15mgtar in forum Mach Software (ArtSoft software)
    Last Post: 10-19-2009, 09:25 AM
  5. Limit Switch Triggered??
    By H2ODiver in forum Mach Mill
    Last Post: 02-22-2007, 06:48 PM
