586,096 active members*
3,396 visitors online*
IndustryArena Forum > MetalWorking Machines > EMCO CNC Machines > Winnc 13.76 Will it run on newer than win 98?
Results 1 to 2 of 2
    Jul 2009
    219
    I recently lost the mobo on my Emco 325II Lathe. I was told ,y version 13.76 would only run on win 98. Has anyone had luck getting it to work on a newer version of Windows?
    TIA,
    Eric
    Sep 2011
    60
    Re: Winnc 13.76 Will it run on newer than win 98?
    Quote Originally Posted by A1CNC View Post
    TIA,
    Eric
    The software will run, but you will have timing problems communicating with the machine. After Win 98 the OS had control of the parallel port timing not the software. This causes lots of issues with Gcode.
    If you do not want win98, you will need to recondition the controls (bring them up to date). It is an expensive and in depth job. Not hard. but does require some knowledge of how cnc controls work.
  1. WinNC software?
    By Diesel_Pilot in forum EMCO CNC Machines
    Last Post: 05-10-2017, 11:58 PM
  2. Help With Jogging Using Fanuc 21 and WinNC
    By smokediver576 in forum EMCO CNC Machines
    Last Post: 02-12-2016, 11:26 PM
  3. Emco Winnc
    By jberend in forum EMCO CNC Machines
    Last Post: 12-12-2014, 01:36 AM
  4. Is WinNC required for CAD/CAM?
    By Miguel.Hermanns in forum EMCO CNC Machines
    Last Post: 01-04-2011, 11:48 PM
  5. WinNC
    By jotaba in forum Spanish
    Last Post: 12-15-2010, 12:43 AM
