586,069 active members*
3,608 visitors online*
IndustryArena Forum > CAM Software > Mastercam > Toolpath roll over
    Jan 2012
    55
    Toolpath roll over
    Good Morning,
    I am trying to cut a contoured slot through a part and can't seem to stop the cutter from rolling over when exiting. I'm sure this is something very simple what am I missing?
    I attached an image of what I'm trying to avoid. One thing I did try with limited success was going into the advanced settings on the parameters page and setting the "Roll Tool" to "only between surfaces" this worked but I wanted the cutter to exit the part the distance of my containment box. and this setting made it so it stopped at the edge of my part.
    I also attached my solid part in a .zip if anyone wants to take a stab at it, I am using Mastercam 2017. My goal was to have the cutter exit the part by .250 on each end, machining just the contoured slot as the rest of the part is finished.
    Aug 2008
    406
    Re: Toolpath roll over
    Try this
    Attached Files Attached Files
  1. Laser die cutting machine in roll to roll mode -need help-
    By adamcio25 in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 09-09-2015, 03:11 AM
  2. Replies: 0
    Last Post: 09-08-2015, 09:54 PM
  3. Simple question: Hot roll vs cold roll steel
    By CuttersCov in forum MetalWork Discussion
    Last Post: 01-10-2013, 02:42 PM
  4. hacking a roll to roll tape printer
    By ybakos in forum Printing, Scanners, Vinyl cutting and Plotters
    Last Post: 12-17-2009, 11:22 PM
  5. Roll tapping.
    By Mitsui Seiki in forum G-Code Programing
    Last Post: 06-17-2008, 05:37 AM
