586,068 active members*
3,876 visitors online*
IndustryArena Forum > Material Technology > Glass, Plastic and Stone > Is there a way to machine (facing) concrete?
Results 1 to 6 of 6
    Oct 2017
    Hi all,
    I have concrete cylinders that are for compression and tensile testing. In order for them to be tested the concrete must be perpendicular on each end to the "side" of the cylinder. Is there a way to face the ends of the cylinder? I was thinking about PCD inserts but I am worried about blowing up my tooling when I hit rocks and such things in the concrete. The inserts in question are nearly $800 for a set and I can't really blow up $800. I don't even know if concrete is machinable.
    Thanks!
    Aug 2011
    Re: Is there a way to machine (facing) concrete?
    Quote Originally Posted by Cbyron View Post
    Hi all,
    Thanks!
    The technology already exists and is very low-tech. A concrete block saw with some kind of vice will hold and cut them perfectly square on the ends. They utilise a blade of around 14" diameter, have a foot-treddle for applying pressure to the cut and a sliding table for back& forth motion.
    A simple tile saw should cut the ends.
    Aug 2011
    It would in principle but tiles saws use blades that are too small to cut your average 4" test core, and the motors are quite low powered in comparison.
    Dec 2013
    5717
    Put a diamond concrete blade on a cutoff saw. Might require a water stream, but I think some of them are designed to cut dry.
    Jim Dawson
    Sandy, Oregon, USA
    Jan 2010
    22
    I thought you cast end caps on the test cylinders out of sulfur before putting it in a testing machine. Compression only. If you contact a soils lab they should have all the equipment you need.
  1. Replies: 5052
    Last Post: 02-08-2024, 12:42 AM
  2. portland cement concrete machine base
    By js412000 in forum Mechanical Calculations/Engineering Design
    Last Post: 10-28-2017, 07:02 PM
  3. looking for a new facing and centering machine
    By gokhan in forum Want To Buy...Need help!
    Last Post: 11-09-2011, 04:55 PM
  4. Reinforced concrete damping for steel machine structures.
    By JohnMcNamara in forum Epoxy Granite
    Last Post: 04-24-2011, 08:02 PM
  5. Machine base made of polymer concrete
    By Steven.ji in forum Uncategorised MetalWorking Machines
    Last Post: 08-17-2009, 02:38 AM
