586,033 active members*
3,532 visitors online*
IndustryArena Forum > MetalWorking Machines > Cincinnati CNC > 1997 Cincinnati Arrow 1000 (A2100) - Communication Board
    Jan 2014
    10
    Hi all,
    Has anyone ever encountered the LEDs and relays on the communication board flickering? When main power is turned on the LEDs over relays CR12,13,14,15&18 are dim and are flickering on and off. Seems like there is a short somewhere. I checked the 24VDC power supply, I'm getting good voltage there.
    I have tried starting the machine but it will not make it thru alignment. Getting a number of random errors.
    Any help is greatly appreciated.
    Thanks!
    Kyle
    Sep 2008
    100
    Re: 1997 Cincinnati Arrow 1000 (A2100) - Communication Board
    I recently had a similar problem, there was a short on the cards I/O
    Dec 2006
    584
    You should look at the I/O card in the A2100 control, that is what turns on the relays. Also look at the AC ripple on the 24VDC supply by turning your meter to AC when connected to the DC supply, it should be under 1 VAC. Also look at all the connections and ribbon cables connected to the board and the A2100 I/O card.
    MIKE CNC Machine Services INC | Cincinnati Milacron MachinesCNC Machine Services
  1. Cincinnati Milacron Arrow 1000 A2100 - relocated - HELP!
    By veggiedawg in forum Cincinnati CNC
    Last Post: 11-17-2022, 03:00 PM
  2. Cincinnati arrow 1000 A2100 - having problem alignment
    By JFYM88 in forum North America RFQ's
    Last Post: 06-03-2017, 03:47 PM
  3. Need A2100 software for arrow 1000
    By matthew6060 in forum Cincinnati CNC
    Last Post: 06-02-2017, 09:13 AM
  4. cincinnati arrow 500 with acramatic A2100 control
    By alopez920 in forum Community Club House
    Last Post: 01-24-2014, 12:46 AM
  5. A2100 - Arrow 1000: Operating System Lost
    By JTG2003 in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 04-09-2010, 04:33 AM
