586,069 active members*
3,363 visitors online*
IndustryArena Forum > MetalWorking Machines > Uncategorised MetalWorking Machines > CNC Drill Gantry/Router Recommended OEM's for Steel Panels
    Oct 2011
    12
    Looking for feedback on 3 axis CNC drill gantry/router OEM systems for our manufacturing facility:
    1. NOT China made (prefer made in USA if an option for local support)
    2. FERROUS metal machining
    3. Drill and tapping holes from 1/8-1/2"D
    4. Possible spot facing off paint in small areas for ground points
    5. Tool carousel of more than a few tools (~12-20 perhaps)
    6. Capable of processing panels up to 72"Wx72"L (give or take) x1"H x ~0.125" thick steel (no Stainless)
    7. CAD files made in AutoCAD and using Promise-E - direct import to run posted files
    Thanks for help!
    Dec 2013
    5717
    Re: CNC Drill Gantry/Router Recommended OEM's for Steel Panels
    What is your budget? That will dictate the best option.
    Your item 7 might be a problem. As far as I know there is no machine control software that will directly accept a file from AutoCad or Promise-E. Normally save as a DXF and then use a CAM program to generate the G-code to run the machine. Not a big problem but that's the way it's done.
    I am very familiar with what you are wanting to do, in fact I'm doing a panel tomorrow on my mill. Both the back panel and the door cutouts for instrumentation. In this case it's a 24x24. I don't know what steel grade they make panels out of, but it is a PITA to machine.
    If I were going to set up to do up to 72x72, I would buy a heavy, used industrial router and put a milling machine head on it. Router spindles turn much too fast for what you want to do. There are several ways to handle the tool changing. In this case I would probably make a rack style. Unless you can find a large gantry mill or huge VMC, you are probably going to have to modify a machine to fit your needs.
    If you can find Thermwood router, that would make a good base. Those things are built like a tank.
    Jim Dawson
    Sandy, Oregon, USA
    Oct 2011
    12
    Jim,
    I agree on item 7 - not have my rookie CNC hat on. We have a Haas Mini Mill we use for machining plastics and use BobCAD for the CAM using AutoCAD files merged in.
    Definitely looking to buy a turnkey machine vs. putting a system together.
    Today's method: We currently have an old manual 4 spindle head drill head we have drill bits in (tapping done by hand drill). The drill head is mounted to a large Bosch gantry structure that the operator moves over the holes on an M-lay CAD file print out taped to the panel. Way past due to be updated but more so as newer parent company spilled lots more volume at us.
    I have been just starting to check on drill gantries but finding for ferrous is the key. Gantry mill or VMC would get pricey I am betting but want to see where at. Enclosure manufacturers have their own systems that they sell and know owners of these as do panel mods and enclosures. I do not intend to do enclosure machining in-house so wanted to see if lower cost panel mod machining capabilities only. Hoffman/Steinhauer and Rittal have systems.
    Thanks for input.
    Brad
    Sep 2008
    140
    Probably more capacity than you need, but worth taking a look.
    https://www.peddinghaus.com/plasma-c...lateprocessors
    Peddinghaus, in my opinion, is the king of plate processors.
    Larry
  1. Lessons in overkill! Welded steel, fixed gantry router
    By mcentric in forum DIY CNC Router Table Machines
    Last Post: 10-23-2018, 08:53 AM
  2. 80/20 and Steel Gantry Router Build
    By Adamj12b in forum DIY CNC Router Table Machines
    Last Post: 07-26-2015, 06:11 PM
  3. Steel Gantry Wood Router
    By gavztheouch in forum DIY CNC Router Table Machines
    Last Post: 09-01-2012, 06:37 PM
  4. 2nd Build - Steel Tube, Moving Gantry Style, Mill / Router
    By InventIt in forum Vertical Mill, Lathe Project Log
    Last Post: 02-26-2012, 08:15 AM
  5. Can I drill AISI 1020 plate steel with a drill bit?
    By Apples in forum MetalWork Discussion
    Last Post: 02-01-2006, 06:15 PM
