586,121 active members*
3,485 visitors online*
    Jul 2009
    16
    x2 Mill upgrade to CNC
    I have started my cnc upgrade, HF X2 mini mill.
    I call it the "Blue OX"
    Here is what I have done so far:
    1. LMS Larger base:
    2. LMS Solid Column
    3. New placement of head.
    4. Added ball screw to Z-axis
    5. Air shock.
    6. Ball screws Z & Y axis
    Attachment 376450
    The mounting plate for the head looks off and it is. When I did the layout I did not center the head assembly on the back plane. The heads are spot on and only odd looking item is the mounting block. I am new at this and make some mistakes.
    You can see that I got the Z-axis ball screw installed and it does work well. I am setting up the Y-axis now, the ball screw is longer the what it was before and the end of the ball screw has a bearing on it set in the back of the base mount. I am going to mount the motor off to the right as pictured so as not to have it protruding out the front of the mill.
    I do not have another mill so I am using my 8x12/14 lathe as a mill and added a mount to hod pieces for milling.
    I added a HF vice that I took apart and did the following:
    1. lapped all slides to remove machining marks and paint.
    2. add new handles
    3. and rearranged the vice so I could get at the handles and gib set screws which I chained to socket head screws.
    Attachment 376466
    This is the test mounting of the vice and I will add a newer photo latter.
    I was able to get all the movement out of the vice and by using the z-axis break I got it to stop moving.
    This whole thing is trail and error.
    If there is anyone in my area that can help it would be great, Chino Valley AZ. USA
    Jul 2009
    16
    Re: x2 Mill upgrade to CNC
    After getting ready to dress up the items that I made I have found some problems with the head mounting and have taken correcting action on those will post the update in a few days...(chair)
  1. F1P CNC mill CAD/CAM upgrade
    By OLDTOAD in forum EMCO Mills
    Last Post: 05-15-2014, 11:03 AM
  2. Help me upgrade my mill
    By Ed from NY in forum Syil Products
    Last Post: 02-22-2011, 04:00 AM
  3. CNC Masters upgrade for the RF-45 mill
    By mikefayettev in forum Charter Oak Automation Support Forum
    Last Post: 05-28-2010, 11:24 PM
  4. 12Z mill cnc upgrade
    Last Post: 05-27-2010, 06:02 PM
  5. IH mill motor upgrade
    By Randall in forum Charter Oak Automation Support Forum
    Last Post: 11-14-2005, 09:04 PM
