586,061 active members*
4,694 visitors online*
IndustryArena Forum > MetalWorking > MetalWork Discussion > Issue - Milling a rounded bottom model , at finishing pass leaves a flat area.
    Oct 2017
    Hi There,
    I've been following this forum since a couple of years, now I need som help to solve an issue I have when milling round parts.
    As you can see at the following pictures I'm having some issues with the finishing pass. The bottom is suposed to be round but at the finishing pass an almost flat area appear (not totally flat, but with a much higher radious than it should)
    I use Rhino for CAM and Rhinocam as CAM. Milling machine is a Syil x4 speedmaster and I'm using Mach3,
    Any clue about whats going on?
    Thanks!!
    Apr 2005
    149
    Re: Issue - Milling a rounded bottom model , at finishing pass leaves a flat area.
    What tool are you using?? It looks like perhaps the tool radius is too large for the part radius???? Can't really tell. Is your CAM package showing a good path? A path without the flat spot? Is that recessed?
    Oct 2017
    Thanks for your Help Ican. I'm Using a 3mm ball endmill, but happens also with other tools, doesn't matter how small they are or how big is the radius, it's always the same thing... The CAM shows a perfect path, no flat spot at the bottom. It looks like there is still material to be removed, the endmill doesn't get down enough
    Jan 2007
    4
    Have you checked for wear in the feedscrews?
    From the picture it looks as if the error comes with a change of direction up/down or down/up, so any wear in the screws is exaggerated with the change of direction.
    Pete
    Apr 2005
    149
    Quote Originally Posted by ChrisGalmiche View Post
    Odd. Since it isn't showing in your path in your CAM program, I would look at the tool description and make sure the CAM has the correct tool information to path from. As well, path the part wit a little different path...say on an angle with a little X in the movement. like this ///////// instead of all Y moves. It could be machine wear but if that is the case, I'd think it would show up in other parts being cut as well. One last thought... in the image, it looks like the tool is cutting...but at a different height as far as I can tell. Look at the code where the tool passes over that area, see if there are any Z moves. The way it looks, IF there are Z moves there will be a pattern you might be able to spot. That part is thin.... is it flexing?? Doesn't look like it but you gotta get this fixed....it's driving me nuts!!! Good Luck
  1. Laser cutting a multi-pass rounded rectangle not tracking
    By rfresh737 in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 08-11-2016, 04:46 AM
  2. Finishing Pass is above model
    By manyhats2007 in forum Uncategorised CAM Discussion
    Last Post: 07-30-2014, 06:02 PM
  3. Eliminating Tool marks in bottom of flat-bottom pocket
    By toyranosaur in forum MetalWork Discussion
    Last Post: 04-20-2012, 05:36 PM
  4. End mill leaves circles on bottom of pocket
    By TXFred in forum Tormach Personal CNC Mill
    Last Post: 04-03-2012, 04:41 PM
  5. pocket milling - don't want finishing pass
    By jay_dizzle in forum BobCad-Cam
    Last Post: 10-15-2010, 09:13 AM
