586,051 active members*
3,688 visitors online*
IndustryArena Forum > MetalWorking Machines > Hitachi Seikis > Hitachi Seiki TF20 Help ! ! Please
Results 1 to 14 of 14
    Mar 2007
    3
    Hi , this is my first post on this site so i apologise if it is a bit long winded.
    C.N.C machining is relatively new to me , i have only got 4 ish years or experience and only 3 on this machine. All three without problem . Until now...
    Could any of you guys please help me with a hitachi seiki lathe type TF20 with Fanuc series 21-T controls ? The problem started when a part came free from the chuck whilst being machined. This has happened numerous times , all without serious consequence . This time however , after hitting the emergency stop button , i noticed a torque alarm , i didnt note the number as it cleared too quickly! I then moved the turret clear of the jaws and tried to zero return the machine as usual , but at the end of the Z return cycle , it stops and shows
    506 over travel +X
    It does the X axis first as normal without problem , but near the end of the Z cycle the alarm triggers , showing an overtravel on X. Strange?
    506 is the hardware overtravel , but the limit switch is not hit by the dog.
    Also there is an external alarm , 1005 , for which there is no reference in the alarm list in fanucs manual , and i do not have the maintenance volume of the seiki literature.
    I have tried to remedy this by the P and cancel buttons on power up , but this does not work , nor does adjusting the x or z axis with the 1850 grid shift parameter , the machine just halts at the end of z zero.
    Should i be able to set the reference point by software or is it necessary to adjust the ball screw ( a procedure i know next to nothing about!)
    Thanks in advice people , any help would be , well , really helpfull !!
    Great site by the way.
    Cheers
    Mar 2005
    17
    The Hitachi Seiki I ran had a clutch that would pop out in case of a crash. It is really easy to pop back in place once you know where it is at. There is one on both the x and z axis. If you are unfamiliar with the clutch and need help locating it let me know.
    Good Luck
    Mar 2007
    3
    I managed to sort the overtravel out ! ! At last. I used the grid shift page , but this time , contrary to what the manual says , I powered down immediately after changing the value . Previously I was inputting a value , disabling the parameter write enable , then powering down then back up. Anyhow its back up and running now , with only a few minor changes to the offsets to be made.
    Mar 2011
    hello,
    I am having Hitachi Seiki TF20 with FANUC 21T controller similar machine now I lost PMC parameters,
    If you send me the PMC parameter it will be great help to me.
    I tried with MTB but I found poor response from them.
    Please help me,
    thanks
    Jan 2008
    5
    HITACHI SEIKI TF20 FANUC 21T PARAMETERS
    Here is the parameters for your Hitachi Seiki TF20 with FANUC 21T.
    NOW, We have the same Hitachi Seiki TF20 with FANUC 21T control and WE NEED THE LADDER BACKUP FILE, because we have ROM Initialize troubles and we can not start the lathe.
    I just attached the 4 files we have but we need the LADDER file.
    It seems like must be 5 files for this backup, 21nc, 21off, 21pmc, 21pro but our technician says LADDER FILE IS MISSING. HEEEEELP US PLEASE...!!!
    Oct 2008
    3
    were you able to solve this issue?
    We are dealing exactly with the same issue.
    Dec 2009
    539
    What is the issue you are having, I can probably help.
    John
    Mar 2007
    3
    ITACHI CNC TF20
    I dear sir, please can you help on a backup of parameter´s?
    please we need a copy of parameter´s and pmc parameters.
    besr regards in advance
    please use my direct e-mail
    [email protected]
    Jan 2022
    Re: Hitachi Seiki TF20 Help ! ! Please
    Hello,
    We have a similar problem with our Hitachi Seiki TF20 Lathe . We had battery problem with POWERMATE and we don’t hava a backup of Power Mate also. Now we are trying to find a backup of Powermate from the same machine. Can anyone help me about that?
    Jan 2022
    We have a similar problem with our Hitachi Seiki TF20 Lathe . We had battery problem with POWERMATE and we don’t hava a backup of Power Mate also. Now we are trying to find a backup of Powermate from the same machine. Can you help me about that? please e-mail [email protected]
    Dec 2009
    539
    Hello
    I will send you an email
    John
    Mar 2023
    Hello,
    I also have a problem with this machine. The 6V battery was bad. Data loss. The memory card does not work. Can you help me?
    Thank you
    Marian
    Dec 2009
    539
    Hello
    Send me a message with your email and I will assist you!
    John
    Quote Originally Posted by Marvi View Post
    Hello,
    Thank you
    Marian
    Feb 2017
    Hi John (shas595), could you send me the backup data for the SEIKI TF20 machine. [email protected]
  1. Hitachi Seiki TF20
    By rai in forum Fanuc
    Last Post: 10-06-2022, 11:13 AM
  2. Hitachi Seiki TF20 Fanuc PowerMate-E
    By Machine Care in forum Hitachi Seikis
    Last Post: 01-24-2022, 11:42 AM
  3. Not sure if Hitachi Seiki goes in here too....
    By gilchapa in forum Mori Seiki lathes
    Last Post: 05-03-2012, 10:31 PM
  4. Hitachi Seiki HG-630
    By Jim Green in forum Mori Seiki Mills
    Last Post: 03-01-2012, 11:36 PM
  5. Did Mori Seiki Buy Hitachi Seiki?
    By Billet Sean in forum Mori Seiki lathes
    Last Post: 05-05-2011, 04:12 AM
