586,051 active members*
3,848 visitors online*
IndustryArena Forum > Material Technology > Material Machining Solutions > Micro Machining with 0.1mm dia cutter any one?
    Oct 2017
    Hi all, any one have any experience with 0.1mm end mill running in 316L stainless? Is this even possible, I have a good spindel able to do better than 100k RPM if needed, but that's about it, so any comments welcome.
    Sep 2006
    245
    Re: Micro Machining with 0.1mm dia cutter any one?
    Are you talking about a tapered bit with a 0.1mm tip? Or is it really a 0.1mm endmill? I couldn't imagine cutting plastic or wood with a 0.1mm endmill unless your machine is extremely accurate. The smallest amount of backlash or flex would snap a bit that tiny.
    Steve
    Oct 2017
    Quote Originally Posted by steve323 View Post
    Steve
    Yes, you have it 0.1mm diameter straight, 2 flute, with a length of 0.3mm with a total depth of cut of about 0.5mm, insane I know, I think the air spindle will be running about 80k and a feed of about 100 mm/min and a depth of cut of 20-25 microns, I will have to build a machine to do this, using micrometers as lead screws and linear ball tracks.
    Dec 2013
    5717
    An ambitious project. Would love to see pictures as you build. I have run a 5° tapered end mill with a 0.15 mm tip, cutting 0.75 mm DOC, ~50,000 RPM, cutting 360 brass on my mill so I know that's possible. Should work fine with a tight and heavy machine. The mass of the machine helps with the tool killing vibration.
    Ran about 500 of these, about 8 hours of run time.
    Jim Dawson
    Sandy, Oregon, USA
  1. Machining micro holes
    By hubihubi2 in forum MetalWork Discussion
    Last Post: 11-24-2016, 01:45 AM
  2. Micro Machining
    By tobyaxis in forum MetalWork Discussion
    Last Post: 06-16-2015, 10:49 PM
  3. Micro Machining with Vcarve Pro
    By inov8r in forum PhotoVCarve and VCarve Pro
    Last Post: 01-19-2014, 06:36 AM
  4. Micro-Machining
    By Fixittt in forum Benchtop Machines
    Last Post: 12-19-2008, 03:45 PM
  5. Getting into Micro-Machining
    By adaptforge in forum Uncategorised MetalWorking Machines
    Last Post: 06-15-2007, 05:54 PM
