586,111 active members*
3,232 visitors online*
IndustryArena Forum > MetalWorking > MetalWork Discussion > How/what machine to shape a thin stainless plate to become a "half" egg shape ?
Results 1 to 6 of 6
    Feb 2005
    234
    I'm looking for a machine to shape a thin stainless steel to become a half egg shape, small size... about 10 inch or smaller.
    which machine and what you called it to do that job ?
    pounding machine does that or what ?
    I need very smooth result for thin stainless steel material.
    help please.
    regards
    cal
    Jul 2005
    12177
    Search on 'Metal Spinning' this is how sheet material can be formed into shapes like you want.
    Feb 2005
    234
    thanks, but how about doing the non symetrical shape ?
    cal
    Jul 2005
    12177
    Quote Originally Posted by Calico View Post
    cal
    Ah, you mean half an egg longways not half an egg crossway which would be rotationally symmetric.
    I guess a hammer and a form is the answer but my field is things that go round like lathes so I am not much help here.
    Feb 2007
    664
    you can use an English wheel
    just one of many links ,Google English wheel
    www.techspot.com/vb/topic18654.html
    Oct 2005
    1238
    Arrow Nibbling Machine
    A search for "Nibbling Machine" will show what you require.
    These machines have various dies/cutters depending upon shapes required.
    They will shear, slot, louver, bead, dish, planish etc.
    The proper shaped planishing or dishing tools fitted to the machine, will give the shape you require with very smooth finish if used properly.
  1. Tube Bending Machine Capable of 2"x4" Rectangular Tubing
    By morribi in forum Bending, Forging, Extrusion...
    Last Post: 06-27-2010, 04:47 PM
  2. Ren Shape
    By cadman in forum Material Machining Solutions
    Last Post: 06-02-2009, 12:18 PM
  3. Alternatives to "Solar flux" stainless welding flux?
    By chingon in forum Welding Brazing Soldering Sealing
    Last Post: 03-12-2007, 11:34 AM
  4. Questions on building small (18" x 24" x 3") machine
    By bikedude880 in forum DIY CNC Router Table Machines
    Last Post: 08-01-2006, 03:04 AM
