586,075 active members*
4,116 visitors online*
Thread: Z lift
Results 1 to 9 of 9
    Apr 2017
    77
    Z lift
    Hi
    Im having a issue where when i zero my z and start to cut after about 10 mins in the cut the z axis has moved higher than when it was originally zeroed.
    can anyone point me in the right direction on how to trouble shoot this?
    Re: Z lift
    Decrease your Z axis acceleration by 25%-50%, and see if that helps.
    How much is it out of position?
    Apr 2017
    77
    Re: Z lift
    the longer the job carries on the more it goes out.
    Ive also tested this without actually cutting into the material and i get the same results. Ill try decreasing acc and see what happens
    Apr 2017
    77
    Re: Z lift
    I have tried reducing acceleration and it still does it.
    Ive removed the spindle and ran the code without that attached and it still lifts.
    I zero it run the job for one minute and then go back to zero and the high of the z has moved up.
    Not sure what else to try any suggestions?
    Apr 2016
    12
    Re: Z lift
    Did you try to change steps per unit? Does the spindle goes as high or as low you say to go?
    Sent from my HTC Desire 620G dual sim using Tapatalk
    Mar 2013
    140
    Re: Z lift
    Does the machine have gas struts or pneumatic cylinder to assist the z axis against gravity?
    Apr 2017
    77
    Re: Z lift
    Quote Originally Posted by manofmanyhats View Post
    not on my china cnc
    Mar 2013
    140
    Re: Z lift
    With power not going to the z axis motor, can you move the axis by turning the ballscrew? Is it difficult?
    Could be alignment issues, could be linear bearings issue etc.
    Apr 2017
    77
    Re: Z lift
    I've sorted this now.
    I swapped the stepper motors around and stepper drivers but I noted on aspire I was performing a pocket but using a profile tool path instead of a pocket. but which ever of the above seemed to fix the issue.
    Sent from my SM-N910F using Tapatalk
  1. Vertical lift platform-vertical lift table in China
    By mornlifttable in forum News Announcements
    Last Post: 06-28-2012, 04:30 AM
  2. Lift day
    By cncadmin in forum EnRoute
    Last Post: 06-16-2012, 11:20 PM
  3. X4 - How to lift?
    By andy_rb in forum Syil Products
    Last Post: 05-10-2009, 08:22 PM
  4. I Have Lift Off !
    By SPEEDRE in forum Machines running Mach Software
    Last Post: 07-10-2008, 03:28 PM
  5. Where to lift up IH ?
    By Juka in forum Charter Oak Automation Support Forum
    Last Post: 07-19-2007, 05:26 AM
