586,061 active members*
4,345 visitors online*
    Sep 2017
    33
    V Carve last pass feature?
    Hello again.
    Can you give me a bit of advise?
    I'm cutting 9mm MDF with 3 passes for a logo protect. When its finished, there are 2 lines showing on the edge (from the separate passes). I can sand them out but its quite time consuming.
    I saw the feature that lets the last pass have a separate offset, so I made it 0.2 and its definitely better, but still not a clean flat edge.
    Will the additional 'reverse on last pass' function improve this?
    Thanks.
    Re: V Carve last pass feature?
    It may, IF you climb cut the first passes, and conventional cut the final pass.
    Make sure your spindle is perfectly trammed (perpendicular to the table).
    It sounds like you machine has a fair amount of flex.
    Sep 2017
    33
    Its a pretty solid machine. Don't think theres any flex tbh. I will check the spindle. Thanks for suggestions.
    If there's no flex, then you shouldn't be seeing any lines, if the spindle is trammed.
    Sep 2017
    33
    How do I tram the Spindle?
    Its a Kress btw.
  1. Bad cut on second pass
    By L0UIE in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 05-31-2017, 01:11 PM
  2. Replies: 8
    Last Post: 07-18-2012, 10:51 PM
  3. Dill feature without center drill feature
    By LockTech in forum BobCad-Cam
    Last Post: 08-25-2011, 02:38 PM
  4. Pass Through?
    By Jtron5 in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 02-09-2011, 09:45 PM
