586,067 active members*
5,437 visitors online*
IndustryArena Forum > CAM Software > MadCAM > Z-Remachining giving unexpected/incomplete results
    Nov 2013
    36
    Hi All,
    I have used remachining (mostly Zlevel for 2.5D projects) in the past with varying degrees of success (some very), but I am curious how to make it function more consistently. In the image I have a form with inside corners I would like to have cleaned up with a smaller bit, but the remachining op seems to have only gone for 2 areas on the form, neither of which were the actual corners, and left the majority of corners untouched. Am I doing something wrong or missing something conceptually?
    Many thanks, O
    The outer complete path was a Z finishing pass (I am cutting plywood) with a 0.500" dia endmill
    The inner incomplete path is 0.125"dia endmill and found only in highlighted corners.
    Nov 2013
    36
    Re: Z-Remachining giving unexpected/incomplete results
    Hi there,
    Is there anyone else who is experiencing this? Attached is a picture of how it used to work back in September.
    Many thanksAttachment 378002
  1. Unexpected Results
    By woodsona in forum Uncategorised CAM Discussion
    Last Post: 12-07-2017, 08:26 PM
  2. V23 sweep funtion, unexpected results
    By vetsen in forum BobCad-Cam
    Last Post: 09-16-2012, 01:23 AM
  3. Remachining removing too much material
    By mspaw in forum MadCAM
    Last Post: 07-20-2011, 11:32 AM
  4. Remachining
    By johny0407 in forum Mastercam
    Last Post: 05-21-2009, 01:34 PM
  5. Remachining
    By MagTDK in forum MadCAM
    Last Post: 12-17-2006, 12:36 PM
