586,704 active members*
2,475 visitors online*
    Nov 2017
    CALIBRATION ISSUES
    Hi there!
    I am using a CNC 3020T with your USB CNC Controller software and I am having problems with the calibration process.
    I have used the "axis SPU calibration" in File>>settings>>Axes. I am able to calibrate the distance on a displacement of 100mm on positive X direction after some iterations. However, after that, if I command it to move the same 100mm in the negative X, it travels way farther (around 145mm) and I ignore why.
    First I thought it could have to do with a mechanical issue on the machine, but I reversed the direction of the axis so that a command to move in the positive would move in what previously was negative direction. then I calibrated in the positive direction just as before (but now physically moving in the opposite sense), and when I commanded it to move 100mm in the negative it still moved longer than it should.
    The same occurs with the Y axis.
    I tried the traversing at different speeds at it didn't solve it either.
    I would appreciate if anyone could help me understand why the SPU seem to change depending on the direction of movement within the same axis, and how I could solve this problem. I have the feeling I am missing on something related to the settings of the device.
    Thanks.
    Mar 2017
    1319
    Re: CALIBRATION ISSUES
    I recommend that you carefully read this tutorial about SPU: https://planet-cnc.com/how-to-setup-cnc/
    After reading it you should be able to set your SPU values correctly.
  1. Marlin delta auto calibration issues
    By dangle86 in forum 3D Printing / Scanning Software and Hardware
    Last Post: 10-17-2017, 03:31 AM
  2. Spindle Calibration Issues
    By ynnek in forum DIY CNC Router Table Machines
    Last Post: 01-16-2017, 03:07 PM
  3. Z axis calibration issues
    By Bad Wolf in forum UCCNC Control Software
    Last Post: 12-18-2015, 02:47 PM
  4. Calibration issues?
    By i-make-robots in forum DIY CNC Router Table Machines
    Last Post: 03-25-2011, 12:21 AM
  5. Axis Calibration Issues
    By 2_many_hobbies in forum Mach Mill
    Last Post: 07-06-2009, 02:34 PM
