586,392 active members*
3,038 visitors online*
IndustryArena Forum > MetalWorking Machines > Hyundai Kia > Hyundai Hit-18s with siemens 840c ERROR 9208 Spindle not in set range.
    Aug 2008
    93
    Exclamation Hyundai Hit-18s with siemens 840c ERROR 9208 Spindle not in set range.
    I was running parts, 2 done 4 to go, After 3rd piece was put in chuck, I pushed start and walked away. I came back expecting a finished part and machine was just sitting there with the spindle turning (looked a little slow) doing nothing. error on screen was # 9208 " spindle not in set range" All I can find on this error is to check the G26 and G92 set points. G26 = 4600 and G92 is at 1500. Machine should have been at 363 RPM and it was showing 212. Power off - reboot, same thing. I cannot find anything on spindle speed calibration or any trouble shooting on this error. HELP.
    Aug 2008
    93
    Re: Hyundai Hit-18s with siemens 840c ERROR 9208 Spindle not in set range.
    Working, I pushed on all the connectors on the simodrive. And it started working, Will update again soon. Going to shut down, pull and re-seat all the plugs.
    Aug 2008
    93
    Re-seating all the connectors did seem to help a little more. Error is now at 0.4% At 1000 RPM machine reads 996 RPM.
    Pretty sure our 15s & 18s lathes are about the same 5-10rpm ut at 1000rpm. You could always check the reading against a tacho & make sure that it's running at the same rpm the control thinks its running at
  1. Hyundai HIT18s with Siemens 840C ...I killed it.
    By BNR_RANDY in forum Hyundai Kia
    Last Post: 01-24-2023, 01:29 PM
  2. Siemens 840C on a '96 Hyundai HiT 30S.........Where do you even begin!?
    By Mykal1970 in forum SIEMENS -> Sinumerik 840C
    Last Post: 01-01-2021, 01:05 AM
  3. Hyundai Hit30s - Siemens 840C
    By Web.eng in forum Hyundai Kia
    Last Post: 12-14-2016, 08:01 AM
  4. post for Hyundai Hit-15s Siemens Sinumerik 840c
    By borutapl in forum Post Processors for MC
    Last Post: 03-04-2016, 03:07 PM
  5. Hyundai Hit8s with siemens 840c
    By Marx in forum Hyundai Kia
    Last Post: 05-30-2009, 08:58 PM
