586,105 active members*
3,000 visitors online*
IndustryArena Forum > MetalWorking Machines > Milltronics > centurion6 doesn't shift to the 2nd speed.
    Oct 2015
    40
    Hi everybody.
    I have a centurion6 control with a 2 speedmotor yaskawa.
    My problem is centurion6 doesn't shift to the 2nd speed when i command a speed over 1500rpm.
    I was searching in my parameters and i didn't find:
    -Shift Spindle on Fly Yes for newer M5 spindle drives with 2 gear spindle motors. The spindle does not need to stop to shift.
    -Electronic Spindle Gear Yes enables the shifting of electronics geared spindle drives.
    I think i don't have the good parameters?
    Are you agree with me?
    Thank you for your help.
    hernault
    Oct 2015
    40
    Re: centurion6 doesn't shift to the 2nd speed.
    Hi.
    I solved the trouble.
    Centurion shift only with a M3 or M4 command.
    Best regards.
    Nov 2013
    128
    If it doesn't need to stop to shift, it would be the only one I've ever seen. Wonder what a set of contacts look like after opening and closing with 20 amps at 220 v going through them. I know that every milltronics I've owned from 1992 through 2014 has had to stop to change speed ranges. Yaskawa, Mitsubishi or CSM, all have had to stop for me. Maybe you know something I don't, but I'll bet it has to see the zero speed output before changing range
    Oct 2015
    40
    Hi Allen mullis.
    You are right. I misspoke. Before understanding how the command of the spindle works i started the spindle with the M3 and increased the speed slowly by s200, s400, s600......But for a command of speed beyond from 1500 rpm the spindle stayed on 1500 rpm. To increase the speed beyond from 1500 rpm centurion needs a new M3 or M4 command. Then the spindle stop and restart to the speed i commanded.
    Best regards.
  1. Need help with a wild centurion6
    By hernault in forum Milltronics
    Last Post: 11-11-2016, 12:40 PM
  2. Need help for centurion6
    Last Post: 11-03-2015, 09:02 PM
  3. rs232 centurion6
    By Fran_k in forum Milltronics
    Last Post: 02-19-2015, 01:43 PM
  4. centurion6 memory problem
    By villalbi in forum Milltronics
    Last Post: 07-18-2013, 06:00 PM
  5. G25 Sheet Shift Speed
    By Kyle1 in forum Fanuc
    Last Post: 04-02-2009, 02:13 PM
