586,060 active members*
4,099 visitors online*
IndustryArena Forum > MetalWorking Machines > EMCO CNC Machines > EMCO Lathe > Emco Turn 55 Spindle motor LENZE 8200 VFD Inverter help
    Aug 2007
    16
    Dear all
    Hope someone can help.
    My Emco Turn 55 had not been used for over 5 years. I finally got round to starting it. When executing a cutting program, the XZ and toolchanger all worked as programmed but the lathe will give a high pitch whine that last for maybe 1-2 seconds or so and then an error message pops up to say "no main spindle speed".
    I took out the back panel to check on the Lenze 8200 Inverter Drive. When I switch on the PC Turn, immediately the Lenze Inverter Green LED started blinking and continue to blink nonstop. It will go solid green when it tried to execute the M3 code and whine. Once the whine stopped, it goes back to blinking.
    I downloaded Lenze manual and it said that it could be "Motor parameter identification being executed" or it could be "Controller Inhibited". I am not sure what either of that means. Could it be that the spindle motor parameter has to be reentered into the Lenze because the memory for the spindle motor was lost?
    Any help is greatly appreciated.
    frank
    Sep 2017
    20
    Re: Emco Turn 55 Spindle motor LENZE 8200 VFD Inverter help
    Hi mate,
    I doubt the parameters have been lost, I work with these drives a fair bit, never really had one lose its memory.
    Do you have the plug in keypad / lcd module on the drive? You'll be able to find the last few fault codes with it.
    Also what is the i/o module in use on the drive - pics are good.
    The funny thing is the drive / motor is making noise - if the controller was inhibited the (no run signal from control, depending on wiring) there would be no output to create noise.
    The solid green light tells me the is a run signal from control, noise tells me there is an output.
    could be a NFG drive, or could be a mechanical problem, can you turn the chuck by hand, is the brake releasing etc....
    The drive could be programmed for a very conservative output, which may not trigger a fault condition in the lenze.
    Jun 2017
    Did you ever get this fixed. Sounds like an adjustment issue with your spindle encoder under the left panel by the pulley. There is slotted philips bolts in there to adjust the pickup from the reluctor wheel. Or a bad encoder.
  1. Replies: 2
    Last Post: 11-07-2017, 07:11 PM
  2. Kflop and Lenze 8200 VFD wiring help
    By isvflorin in forum Dynomotion/Kflop/Kanalog
    Last Post: 05-29-2017, 05:20 PM
  3. Replies: 0
    Last Post: 04-26-2016, 12:21 PM
  4. emco turn 120p with emco tronic ti control
    By rcjacob in forum Vertical Mill, Lathe Project Log
    Last Post: 03-26-2014, 05:01 PM
  5. Replies: 5
    Last Post: 07-19-2013, 05:16 AM
