586,393 active members*
2,787 visitors online*
    Oct 2017
    18
    CNC 6040 - upgrade to KFLOP
    Well...
    This is my workbench
    The machine
    The plate
    Electronics
    Power Supply with Controller and Stepper driver
    The cheap CNC board Controller
    Do not take care of ugly look. This is just a experimental prototype.
    My target is make PCB board for little production, but the cheap CNC Controller have some problem...
    With Mach3 at high speeds (but not so much ...) the controller go to a irreversible loop, moving the axis back and forth in a little loop.
    Due of this I had to throw away a lot of PCBs. So I decided to upgrade the board with a KFLOP board.
    In this thread i walk through the project, step by step.
    Oct 2017
    18
    Re: CNC 6040 - upgrade to KFLOP
    First step:
    Some experiment with KFLOP.
    The custom board is for buffering Output, STEP, DIR and ENABLE command, and serial connection RS232 for remote KFLOP control
    Oct 2017
    18
    Second step:
    Make a PowerSupply KFLOP dedicated board.
    The project on CAD:
    Gerber to G-CODE conversion
    Some step at Simulator to be sure...
    The final result after engraving:
  1. 6040 Router Upgrade
    By hive8 in forum Chinese Machines
    Last Post: 08-30-2022, 03:39 PM
  2. Planning to upgrade my 6040
    By DaMaDo in forum Chinese Machines
    Last Post: 10-26-2017, 08:53 PM
  3. Extend Z Axis upgrade on CNC 6040
    By rjmatseer in forum Chinese Machines
    Last Post: 07-31-2017, 09:04 AM
  4. Gecko 540, UC100 upgrade on Chinese 6040
    By Aeolian in forum Chinese Machines
    Last Post: 07-27-2017, 02:35 AM
  5. Rotation axis upgrade for 6040 router
    By itain in forum Chinese Machines
    Last Post: 10-16-2013, 03:00 PM
