587,035 active members*
2,923 visitors online*
IndustryArena Forum > MetalWorking Machines > Benchtop Machines > Create a (quiet) jet of air blowing without a compressor?
Page 1 of 2 12
Results 1 to 20 of 32
    Sep 2017
    32
    I'm looking for an alternative to compressed air to blow chips without an air compressor.
    Something tells me a desk fan with funnel isn't going to work, not exactly sure why, Google isn't giving me a conclusive answer but I assume that's not feasible.
    Would a small radial blower like small electronics board fan do better?
    I'm just looking for air velocities like blowing with my lips.
    Obviously I'm trying to avoid a noisy compressor for a home garage shop, not drive the neighbors crazy.
    If this is a common newbie question, please link other searched threads.
    Tyson
    Dec 2003
    24223
    Re: Create a (quiet) jet of air blowing without a compressor?
    There are the small air brush compressors that are fairly quiet and if you enclose it in a vented padded enclosure you can barely hear it.
    Al.
    Albert E.
    Sep 2017
    32
    Al.
    that sounds like a reasonable alternative. except when i looked at the price of a silair 20a, im no longer interested. sorry.
    building an enclosure around a noisy air compressor motor is the baseline i'm trying to avoid having to do.
    my current line of thinking is using a 48V electric blower since my power supply is 48V. like this.
    https://www.ebay.com/itm/Delta-Elect...EAAOSwm3pZ98hz
    anyone gone down this road, and found it not simply work?
    Dec 2003
    24223
    Quote Originally Posted by tyson77 View Post
    You are looking in the wrong place!!
    I picked one up for $40.00 complete with air brushes!
    Plus they are not Noisy.!
    Once you restrict the flow of a radial or axial fan, the current goes down, but so does the flow, drastically.
    Al.
    Albert E.
    Dec 2013
    5714
    If volume of air (CFM) remains constant and the nozzle size decreases, then the pressure (and velocity) must go up to push the same CFM through the smaller nozzle. The problem is that a fan is not capable of producing the pressure needed to push high velocity air through a small hole(funnel). Or if it is capable of creating the needed pressure then it gets noisy, think leaf blower.
    There are really quiet air compressors available. California Compressor is one option, available at Home Depot. Also a good shop vac might do it.
    Jim Dawson
    Sandy, Oregon, USA
    Sep 2017
    32
    Would small 12v squirrel cage get me closer? And just curious why does an axial fan not create enough pressure.
    Maybe it was covered in college, but it's been awhile....
    I've seen the reviews of a California air compressor. It's much quieter for sure, but still seems overkill for a bit of blown air. And I'd like something even quieter.
    Dec 2013
    5714
    A squirrel cage fan can be a bit higher pressure than an axial fan, but not by much. The clearances are too loose to be able to build much pressure at the speeds the fan wheel can operate. High pressure can be achieved with a multistage axial fan, like a jet engine. Just keeping things simple, high pressure can be created with a positive displacement pump (air compressor), a turbine wheel, or a multistage system. High pressure, low volume can be achieved at low HP, as can high volume at low pressure. As the pressure AND volume go up, the power requirement goes up as the square of the product. Power = (Vol*PSI)^2 if I remember correctly, and the noise increases accordingly. If you can find a newer Dyson vacuum cleaner to salvage, they have a tiny turbine wheel turning at somewhere around 100K RPM, would be a compact, high pressure system. Probably around 2.5 HP or so.
    Jim Dawson
    Sandy, Oregon, USA
    Aug 2009
    294
    I've been wanting to try this out for awhile. I have no idea how well it works, but I hate buying canned air:
    https://www.canlessair.com/
    Sep 2017
    32
    so i just tested a 24V blower motor that came out of a 3D printer and the results were satisfactory. i necked the output down with my hand and seems like it will be enough to direct chips out of any pockets. runs noticably loud, but probably not more than the mill itself.
    thanks for the suggestions. i think ill just go with that 48v blower.
    Feb 2010
    155
    I use an aquarium pump (that is similar in noise and air pressure to an airbrush pump).
    https://www.amazon.com/Active-Aqua-C.../dp/B002JPPFJ0
    Sep 2017
    32
    Quote Originally Posted by robertk925 View Post
    Ah, you know that seems like a much simpler option.
    I'll keep it in mind. What size pump do you use or recommend? That exact model? There appears to be several different sizes around the web.
    Mar 2017
    926
    I just started looking at this for my CNC machine as I have similar needs.
    For the money, I am tempted to try one or two of these:
    12V, 16CFM, 33mm Blower Fan - RobotShop
    They are so cheap that it doesn't matter if it doesn't work.... if they don't move chips I'll use them for extra cooling.
    The only way I know of to get near silent high pressure jets of air is to get it from a 3000psi scuba or 4500 psi scba tank. With a regulator, you can get an hour or maybe two per fill. Used scba tanks are cheap. I got mine for $115 with fresh hydro and 7 years of life left.
    Obvioulsly this is no good for long jobs and filling them would be a PITA. You can get cheap Chinese 4500 psi compressors to fill them for $500 but it's not very practical overall.
    I have an air brush compressor. I wouldn't use mine for this. They aren't great for continuous use and they are not particularly powerful.
    I have a cheap electric oil vacuum pump 1/8hp which I got for $50 off ebay (for something else). These are quiet (ish) but fill my garage with smoke / vapor after 30 mins of use.
    I have a Thomas oil free 1/2hp vacuum pump and compressor in one. I would recommend this above all the other options suggested here so far. They are rated for continuous use. They are powerful and require little maintenance. My 1/2hp model is not super quiet but it is 20 times quieter and less annoying than my shop vac. The vacuum on it is superior (by miles) and the compressor side is adequate to move chips without needing a seperate regulator.
    Used Thomas pumps are cheap on eBay and readily available. I bet a 1/4hp or 1/8hp model would be even quieter and still powerful enough for this purpose.
    My plan is to run the Thomas pump from another room so I don't have to hear it. If that doesn't work out, I'll make a soundproof enclosure (aka a box lined with sound-proofing foam).
    Btw, don't even consider an electric paint sprayer. I have one that I haven't touched since I got it because it is so loud I can't stand it. It's the worst option here.
    Please let us know if you find a better option. I hate loud noise when I work so much that I have plans to build an insulated brick wall enclosure around my CNC machine.
    Feb 2010
    155
    I use that exact model. I had a smaller one (https://www.amazon.com/EcoPlus-Singl.../dp/B002JLJC0W) but it was a little too weak to clear chips effectively.
    Aug 2006
    673
    I had seen somewhere someone had mounted fan blades directly to the spindle. It seemed to work ok except when the pockets became deep. If you have access to a 3d printer, this could be an easy solution if your spindle runs at higher RPMs
    Nov 2009
    4415
    Quote Originally Posted by CS900 View Post
    That was done by Hoss at my suggestion years ago.
    He actually designed and tested 3 different blade designs. All snapped on to Tormach's tool holders.
    I still have one around here somewhere.
    A lazy man does it twice.
    Jun 2007
    47
    For light duty use a cylinder of co2 would work. Ensure adequate ventilation.
    Sent from my SAMSUNG-SM-G900A using Tapatalk
    Nov 2011
    205
    A little compressor and a big tank.
    Don
    May 2008
    1185
    For my little mill PM-25 I use a blower from a yard blow up Santa. For my larger IH mill I use a blower from a bounce house.
    Keep the hose short and the smaller blowers from the yard decorations work well. 1.5" hose.
    The bounce house blower makes a lot more noise.
    youtube videos of the G0704 under the name arizonavideo99
    Jan 2009
    484
    Maybe this is worth looking in to? https://www.amazon.com/gp/aw/d/B06Y3...+paint+sprayer
    Pull the needle and it would maybe focus an air stream although while it’s quieter than my compressor it’s hardly quiet overall.
    Q: How many tools does it take before a simple task becomes a project?
    A: Just one. I'm the Tool that turns a simple task in to a project.
    Dec 2005
    436
    Some people use the compressor from an old fridge or freezer to feed a tank from the air compressor. They setup is dead silent and delivers the pressure needed to clear chips.
    There are professional compressors that use his setup.
Page 1 of 2 12
  1. Quiet KoolMist compressor thoughts/requirements?
    By macpod in forum Benchtop Machines
    Last Post: 04-11-2012, 03:27 AM
  2. My Quiet Compressor Search
    By TravisR100 in forum Haas Mills
    Last Post: 09-19-2009, 05:10 PM
  3. How to keep it quiet
    By rceebuilder in forum Hobby Discussion
    Last Post: 09-25-2005, 10:43 PM
