586,388 active members*
3,312 visitors online*
IndustryArena Forum > Tools / Tooling Technology > CNC Tooling > 6" Long 1/8-27 NPT Form Tap
    Apr 2005
    903
    Any idea's where one might be purchased without having one made? I can't use a tap extension due to diameter constraints.
    2008 Haas VF2D
    OneCNC XR5 Mill Expert
    Sep 2006
    6463
    Re: 6" Long 1/8-27 NPT Form Tap
    Yeah, turn or grind the top of the tap square to a round section and then drill the end of a steel rod same diam as the tap shank to fit it...........silver solder the tap into the rod end to make a long tap.......BTDT.
    Tig welding the rod directly to the tap without turning it down would also be an option......BTDT too.......done that with drills as well......must be concentric.
    Ian.
  1. Replies: 0
    Last Post: 09-08-2015, 09:54 PM
  2. Thread forming (roll tapping) tips please
    By Toolz_86 in forum MetalWork Discussion
    Last Post: 07-01-2011, 04:33 AM
  3. ring roll forge for thin wall parts, 1" to 4" OD
    By Arnaudb in forum Bending, Forging, Extrusion...
    Last Post: 04-23-2008, 11:01 AM
  4. Vac forming ABS 10foot long x 2"x1" chanel
    By fencer in forum Vacuum forming, Thermoforming etc
    Last Post: 04-22-2008, 05:09 PM
