586,111 active members*
3,146 visitors online*
IndustryArena Forum > MetalWorking Machines > Tormach Personal CNC Mill > Tormach Slant Lathe > largest stock you guys are turning? Slantbed15
Results 1 to 11 of 11
    Nov 2012
    104
    just curious what the largest stock some of you guys are turning, according to tormach no more than 6" diameter stock but they advertise the heck out of the 15" swing. pretty disappointed if this is true.
    Jun 2006
    3063
    Re: largest stock you guys are turning? Slantbed15
    The largest I've turned so far is small lengths of 2" OD 6061 and brass. I did turn some 3-on OD 6061 that was 12" long gripped by ~1/2-in in the 3J chuck and unsupported by a tailstock. That wasn't too bad and the time the work popped out of the chuck was actually pretty uneventful. I was turning at pretty slow speed though.
    Jun 2016
    184
    Largest I have turned was 4.5" 6061 and 2.625" stainless 303.
    6 inch 6061 round bar is largest I've turned. The 15" is nice to have a combo of QCTP and gang tooling (I don't have a turret).
    Nov 2012
    104
    Thanks guys, they advertise the heck out that 15" swing so I figured a 11"-12" round stock would be no problem.
    They should put 6" max stock in there somewhere.
    Again thanks guys
    Oct 2012
    42
    I think it's common for manufactures to specify both swing over bed and swing over carriage. Tormach advertises 6.2 inch diameter over the carriage so while you could face a 11-12" piece 6.2 looks like the max for turning. I used to own a gap bed lathe, you could remove a piece of the bed near the head stock. It was useful for machining flywheels and brake drums and discs that were too large to fit the bed
    Attachment 378532
    Nov 2012
    104
    Yes, I agree. I was hoping to use this for machining flywheels form scratch.
    Thanks for the info
    Jun 2006
    3063
    Quote Originally Posted by TPR View Post
    Thanks for the info
    It looks like the turret on mine can turn an OD of about 15" and nearly 2-1/2" deep in Z before the work would run into the gang tooling block on the slide. I don't have a quick-change toolpost setup on mine but you might get close to a 15-in OD with that as well.
    Nov 2012
    104
    Quote Originally Posted by MichaelHenry View Post
    Are larger chucks even available ?
    Aug 2016
    132
    Shars has 8" and 10" D1-4 chucks.
    Jun 2006
    3063
    A D1-4 faceplate might work well for something like a flywheel too. Those are available in 12-in diameter, I think.
  1. HSMWorks Sucks on Turning be aware Guys
    By brfgmike in forum Autodesk
    Last Post: 07-01-2016, 12:10 AM
  2. Lathe turning tool holder set largest and oldest manufacturer
    By nclathe in forum News Announcements
    Last Post: 12-20-2013, 11:29 AM
  3. V24 Turning Custom stock
    By Sri-09 in forum BobCad-Cam
    Last Post: 05-12-2012, 02:51 PM
  4. Turning Hex Stock
    By osmqc in forum Haas Mills
    Last Post: 03-01-2006, 03:00 PM
