586,065 active members*
4,349 visitors online*
    Jan 2014
    40
    Motor VFD Power matching
    I need to replace my 5.5KW VFD for a different unit.
    I'm offered a 7.5KW VFD for the same price as the 5.5KW VFD.
    The motor is 5.5KW. Can the 7.5KW VFD be used with my 5.5KW motor? Or is it better to replace with a matching unit?
    Nov 2012
    1267
    Re: Motor VFD Power matching
    No, you don't have to match them, a 7.5kW VFD will work perfectly fine for a 5.5kW motor (or even a 1.5kW motor as long as it has the same working voltage).
    May 2011
    790
    Read the manual for the VFD being offered.
    You need to input the V/f curve for the spindle into the VFD parameters as well as setting the current limit.
    Once you input those parameters it shouldn't be any problem whatsoever.
    So do you have 3 phase power? Or is it a single phase to 3 phase VFD you're replacing?
    And is the higher power one the same type (single to 3, or 3 to 3)? That could be a problem if it isn't.
    Jan 2014
    40
    Both VFD's are exactly the same. They are 3P. Only difference is 2kw
    Thanks for the help
  1. Confusion about driver and motor matching
    By PaulMakesThings in forum Stepper Motors / Drives
    Last Post: 01-21-2013, 12:59 AM
  2. Replies: 10
    Last Post: 07-21-2012, 07:20 PM
  3. Matching the right driver to the right motor
    By mcrLABS in forum Automation Technology Products
    Last Post: 09-11-2011, 05:43 PM
  4. matching a power supply
    By krymis in forum CNC Machine Related Electronics
    Last Post: 03-05-2008, 09:10 PM
  5. motor mixing and matching...
    By charleyy in forum DIY CNC Router Table Machines
    Last Post: 09-06-2004, 05:32 AM
