586,110 active members*
3,280 visitors online*
IndustryArena Forum > Community Club House > General Off Topic Discussions > Help converting stl file if possible
Results 1 to 11 of 11
    Nov 2017
    15
    Hello, I am not new to this forum but cannot remember my old credentials...lol so now I am MP40cal.
    Anyway, I bought an expensive $109 obj file of a vehicle. I have converted it to an stl file and am hoping I can somehow wood cnc machine from it. I have VCarve Pro and a number of CAM programs. My problem is when I orient the file to the view I want to machine the file does not get rid of the parts you cannot see. I only want to machine the visible portion of the file. When I import the stl into VCarcve Pro it imports the whole car, so when I look at it from an angle view and drop it into my material the front of the car still protrudes about an inch and a half of the material.
    I know it may be hard to visualize and I may not be explaining very good. I only want to import or cut just the visible portion of the file.
    I have tried to import or attach the picture I am trying to cut.
    Hope it works,
    Thanks everyone. I am in a time crunch and am trying to get this done for my employer.
    Oct 2017
    4
    Re: Help converting stl file if possible
    Do you have Rhino, or something to edit the .obj file with? Then you could zap the unwanted surfaces...
    A screen shot from V Carve would help, as I don't understand what you want to to do?
    Apr 2004
    5737
    What other CAM programs have you got, besides V-carve pro?
    Andrew Werby
    Website
    Nov 2017
    15
    I can provide a screenshot but it’ll be later on today after work.
    Nov 2017
    15
    Sorry for the quick response earlier. I am still at work
    I have Meshlab, 123d Design, inkscape and Sketchup. I know some are not CAM programs but I can use them to change file types.
    I have not heard of Rhino. Is it expensive?
    Mar 2004
    1806
    I recently saw a video by Lars Christensen on how to convert an STL file in Fusion 360
    https://youtu.be/cKXvIWpLoeU
    and
    https://youtu.be/OX1T_bg493A
    This might help you??
    Art
    AKA Country Bubba (Older Than Dirt)
    Oct 2017
    4
    Quote Originally Posted by MP40cal View Post
    I don't use this stuff too much; I am strictly Solid Model these days; Solidwrks, ProEngineer... Rhino is the premium modeller that all the industrial designers use. Supposedly it does *Everything*.
    https://www.genesis-technologies.com...r-windows.html
    So if you can trim the parts you don't want and convert the shaved part to STL again, then you should have it.
    Nov 2017
    15
    Ok, finally got the images from VCarve Pro. As you can see the first image shows where the placement is. The second two show after the object is set it recognizes the whole car and not just what you see. I only want the machined portion to stick up like 1/2" or less. I am hoping to use a 3/4" piece of material.
    Since V Carve can't do undercuts, anything below the model will be filled in. There's really no easy way to clean that up with a full 3D model. What you want is a relief model.
    Nov 2017
    15
    Ok, relief is the word I think I was looking for. Is there any way to make a relief from this type of file?.....Please please say yes!
  1. Replies: 8
    Last Post: 05-04-2015, 12:49 PM
  2. using a data file for both 3D printer and CNC router , Converting file or ???
    By imperial90303 in forum Uncategorised CAM Discussion
    Last Post: 12-17-2014, 01:32 AM
  3. Converting a pdf file to UG part file
    By gaoxingdcf in forum UG NX
    Last Post: 05-20-2010, 01:47 AM
  4. converting a mastercam 9 file into a Solidworks file
    By Michael82 in forum Solidworks
    Last Post: 04-17-2009, 07:14 PM
