586,117 active members*
3,520 visitors online*
IndustryArena Forum > MetalWorking Machines > Benchtop Machines > Simple control software or hardware, simulate manual operation, for CNC?
Results 1 to 18 of 18
    Sep 2017
    32
    I know this might sound backwards, but is there a good way to manipulate your CNC machine using Mach3 so you can operate it more like a manual mill?
    Say I want to edge off some stock material, and square it off on 3 sides.
    On one hand, i dont want to create a CAM program (havent really learned that yet), model the part, and create simple tool path, post process, transfer file, load file and then indicate off and set go. and hope it doesnt crash.
    On the other hand, I'm looking for something more automated than pressing Tab to bring up that jog control, setting motor speeds, then pressing shift-arrow Y, change to jog increment .010", move +.010" x, then repeat.
    Or further on, indicating the edge and then drilling a couple patterns of holes.
    is a pendant the simple answer? prefer a gamepad? is theres a simpler CAM wizard people like to use?
    what do you guys use?
    Tyson
    Re: Simple control software or hardware, simulate manual operation, for CNC?
    MDI?
    Sep 2017
    32
    so MDI, manual data input, you really input single strings of text for each command? for what kind of action do you recommend this?
    Jan 2008
    1529
    I use a gamepad for simple operations. MDI if dimensions matter.
    Feb 2006
    7063
    Get a decent pendant, with a REAL MPG, like a VistaCNC P2S. It will let you do what you want with far better control than a manual machine. You can do nearly everything entirely from the pendant.
    Regards,
    Ray L.
    Sep 2017
    32
    Quote Originally Posted by pippin88 View Post
    i got my old PS2 (wired) controller working with a HDE adapter to USB. using Keygrabber works great. it jogs and high speed moves well.
    I also tried the Joypad plugin. I'm guessing the features it has available is more for fully automated control? it was very much less helpful in my opinion, not quite what i was looking for. and couple times made everything erratic forcing me to e-stop.
    so it got me wondering also, would a numeric keypad be a useful accessory close to the machine? it could be used for even MDI control if i make "5" non-numlock button "G". i could input single lines of code with just the number pad. anyone ever try something like this?
    i'd like to get a "real MPG" one day. just not there yet, part of the fun of it is to tinker and find out other ways to do things...
    A pendant really is a great tool. My cheap Chinese wireless pendant gets used all of the time. It doesn’t matter if I am setting work offsets, simply squaring stock, or just trying to get the bed to an area where I can load a vise or part, it all gets done using the pendant. That said, learning control of MDI is huge too. It’s pretty easy to manually punch in commands to do some surprisingly complex operations.
    1943
    Pendant with a MPG wheel.
    Dec 2004
    95
    My first CNC conversion was a drill press for drilling homemade PCBs. During this I realized how losing manual control, and always having to depend on computer and CNC, was a PITA. Also, realized that the ubiquitous quill/bit automatic spring return on a manual drill press was a functional compromise and often undesirable. My next CNC conversion made sure that full manual operation would always be an option by design and didn't have to be simulated.
    I do miss having the manual drill press function of a manual mill. With MDI however I can close. Of course I have to turn on the machine, turn the software on, jog the table, etc., with a manual machine that single hole I often need to drill would have been done. Then again, my right arm used to ache after an hour or two of running the manual machine even with a power feed on X. Meanwhile my CNC machine ran for 8 hours with no complaints.
    Dec 2004
    95
    Positioning (before CNC G-code execution for example) via manual axis hand wheels can be more efficient than using jog keys and digital wheels when visual feedback is more relevant than exact distance moved.
    Nov 2009
    4415
    Quote Originally Posted by eldata View Post
    Visual feedback? Like that is accurate.
    Personally I will never spin a handle again. I can get where I want in a fraction of the time and I can go to the same place every time, instantly.
    Sent from my iPhone using Tapatalk Pro
    A lazy man does it twice.
    Dec 2004
    95
    Quote Originally Posted by Fastest1 View Post
    CNC hasn't made tools like punches and edge finders obsolete for users of CNC capable machines. Positioning by sight still remains a reality.
    Sent from a desktop with a 28" monitor while reclined and with a margarita in one hand
    Dual 27’s and bourbon here. I don’t do any punch work but my touch probe replaced my edge finder along time ago. Way less messing around. It’s great for setting up multiple work offsets too, I just probe their position and enter the offsets into my CAM and off I go. Manual operation isn’t even in the same league.
    Dec 2004
    95
    Still doesn't refute what I stated which was that using traditional axis hand wheels can be more efficient than using other manual positioning methods like MDI, jog keys or digital wheels.
    Like what?
    Dec 2004
    95
    Rather than hijacking this thread, a new thread with a video demo would probably be the best way to proceed. In the meantime, you've probably noticed that when one updates the time on better digital clocks, the rate of update increases based on the length of time the relevant button is held down. One then releases the button when close to the set target then press it again in order to arrive at the target using a slower update rate. Inferior digital clocks have update rates fixed. Even if they had somewhere to go in and change the rate, it would still be inferior to having on the fly rate change capability.
    Aug 2008
    962
    As an owner of a manual Bridgeport & a CNC Mill .. I'll give a +1 to the electronic controls.
    Moving a machine in .0001 increments CONSISTENTLY with manual hand wheels is tough. A simple flip of a switch and you can move a cnc machine all day long in .0001 increments. or .001, or .01, or .1
  1. Machine control software and hardware for RS-232 servos?
    By PaulMakesThings in forum Servo Motors / Drives
    Last Post: 11-23-2014, 03:08 PM
  2. help for Operation manual for mitsubishi tx8f control
    By saamsong in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 07-21-2012, 04:30 AM
  3. Question: Software, Hardware or no flow control
    By salvadoralvarez in forum Okuma
    Last Post: 11-10-2010, 08:00 PM
  4. Control Software / hardware Reality check
    By DaveODonnell in forum Controller & Computer Solutions
    Last Post: 01-17-2010, 05:05 AM
  5. Replies: 1
    Last Post: 02-25-2007, 09:04 PM
