586,036 active members*
3,712 visitors online*
IndustryArena Forum > CAM Software > Vectric > Aspire > Axis stutters when it hits location of tabs
    May 2011
    i have a test file that is 10x10 square with tabs. While air cutting, the axis(s) stutters when it comes to the location where the tabs are located even though the z depth isn't at the tabs level yet. Through out the g code there are lines of code that are at the location of the tabs even though the z axis isn't at the tab level depth yet. If i run the file without tabs it's silky smooth. It's a really fine stutter but just enough to affect the cut quality. I've tried different post processors but the same result. My machine is a DIY build with chinese drivers etc. If i slow the cut speed down it doesn't stutter. Not sure why those lines of code are at the tab(s) point as they are not needed until the tabs are actually cut?
    Maybe motor tuning?
    Any help would be much appreciated!
    Re: Axis stutters when it hits location of tabs
    What are you controlling the machine with? You should be able to tweak your CV settings to smooth out the motion.
    Aspire has always done this.
    http://www.cnczone.com/forums/diy-cn...code-tabs.html
    May 2011
    Thanks for your quick reply Gerry!
    I'm using Mach 3. It looks like i should check my Mach 3 CV settings.
    I'll mess with it and get back if i still can't get it sorted!
    Cheers,
    Lyle
    A good start is to disable all of the CV settings, but leave CV on.
  1. Replies: 3
    Last Post: 02-12-2016, 01:02 PM
  2. NEED HELP Z Axis goes up hits pumper thatn goes down
    By woodentoysnw in forum Gecko Drives
    Last Post: 02-16-2014, 05:35 PM
  3. CNC is moving slowly and Z axis hits the soft limits
    By kostas1 in forum Mach Software (ArtSoft software)
    Last Post: 01-21-2014, 02:55 PM
  4. Stepper motor stutters.
    By Sinistersam in forum CNC Machine Related Electronics
    Last Post: 12-30-2006, 06:07 AM
