586,377 active members*
3,127 visitors online*
Results 1 to 16 of 16
    Mar 2009
    163
    multicam 5000 weird depth issue
    our router changes depth without being commanded.
    video
    https://youtu.be/PbxTkkshTr8
    code
    M90
    G90
    G71
    G75
    G97 S19500
    G00 T11
    G00 X406.4 Y330.2 Z-13.175
    M12
    G00 Z-4.275
    G01 Z-2.921 F1500.
    F1500.
    G01 X279.4
    G03 X279.4 Y279.4 Z-2.921 I279.4 J304.8
    G01 X406.4
    G02 X406.4 Y228.6 Z-2.921 I406.4 J254.
    G01 X279.4
    G03 X279.4 Y177.8 Z-2.921 I279.4 J203.2
    G01 X406.4
    G02 X406.4 Y127. Z-2.921 I406.4 J152.4
    G01 X279.4
    G03 X279.4 Y76.2 Z-2.921 I279.4 J101.6
    G01 X406.4
    G02 X406.4 Y25.4 Z-2.921 I406.4 J50.8
    G01 X50.8
    G02 X50.8 Y76.2 Z-2.921 I50.8 J50.8
    G01 X177.8
    G03 X177.8 Y127. Z-2.921 I177.8 J101.6
    G01 X50.8
    G02 X50.8 Y177.8 Z-2.921 I50.8 J152.4
    G01 X177.8
    G03 X177.8 Y228.6 Z-2.921 I177.8 J203.2
    G01 X50.8
    G02 X50.8 Y279.4 Z-2.921 I50.8 J254.
    G01 X177.8
    G03 X177.8 Y330.2 Z-2.921 I177.8 J304.8
    G01 X50.8
    M22
    G97 S18000
    G00 T2
    G00 X-4.7525 Y0. Z-13.175
    M12
    G00 Z-4.275
    G01 Z0.381 F1200.
    __________________________________________________ _________________
    http://www.cnczone.com/forums/showthread.php?t=86985 my work in progress
    Mar 2009
    163
    Re: multicam 5000 weird depth issue
    any ideas, its a multicam 5000
    15362
    Quote Originally Posted by diycnc View Post
    The program does not look correct, remove all the Z axes move from the program, they should not be in there, like below
    There are a lot of other codes in this program that also don't look like a fit as well, look up what G and M codes that work with your machine and only use them
    M90
    G90
    G71
    G75
    G97 S19500
    G00 T11
    M12
    G00 Z-4.275
    G01 Z-2.921 F1500.
    F1500.
    G01 X279.4
    G03 X279.4 Y279.4 I279.4 J304.8
    G01 X406.4
    G02 X406.4 Y228.6 I406.4 J254.
    G01 X279.4
    G03 X279.4 Y177.8 I279.4 J203.2
    G01 X406.4
    G02 X406.4 Y127 I406.4 J152.4
    G01 X279.4
    G03 X279.4 Y76.2 I279.4 J101.6
    G01 X406.4
    G02 X406.4 Y25.4 I406.4 J50.8
    G01 X50.8
    G02 X50.8 Y76.2 I50.8 J50.8
    G01 X177.8
    G03 X177.8 Y127. I177.8 J101.6
    G01 X50.8
    G02 X50.8 Y177.8 I50.8 J152.4
    G01 X177.8
    G03 X177.8 Y228.6 I177.8 J203.2
    G01 X50.8
    G02 X50.8 Y279.4 I50.8 J254.
    G01 X177.8
    G03 X177.8 Y330.2 I177.8 J304.8
    G01 X50.8
    M22
    G97 S18000
    G00 T2
    M12
    G00 Z-4.275
    G01 Z0.381 F1200.
    Mactec54
    Mar 2009
    163
    We have been using the same post for 5+ years with no issues.
    Also multicam has supplied a test program and machine still does it, its a problem with archs.
    also looking at your code, its exactly the same as mine, looks like a copy/paste..
    15362
    It is copy/paste, but look again it is completely different
    It could well be a problem with arcs, but the program you posted is incorrect, try what I posted and change the G75 to a G74 and remove the M12
    M90
    G90
    G71
    G75 ( Try a G74 Here )
    G97 S19500
    G00 T11
    M12 ( remove the M12 )
    G00 Z-4.275
    G01 Z-2.921 F1500.
    F1500.
    G01 X279.4
    G01 X406.4
    G01 X279.4
    G01 X406.4
    G01 X279.4
    G01 X406.4
    G01 X50.8
    G01 X177.8
    G01 X50.8
    G01 X177.8
    G01 X50.8
    G01 X177.8
    G01 X50.8
    M22
    G97 S18000
    G00 T2
    M12
    G00 Z-4.275
    G01 Z0.381 F1200.
    Mactec54
    Mar 2009
    163
    OK i looked again and you removed the z depths from the g02/g03 we have already tired with and without the z height listed, no difference, still changes the z while cutting.
    actually if you look in the video there is no z calls on the arch, we tried both ways. i just grabbed the wrong code with while pasting into this forum.
    Jun 2010
    463
    Most of the time with depth issues, especially if you haven't changed software or this is a new install. It is more then likely a mechanical issue, you have taken a test program and the machine did the same thing.
    1. check your belt and pullleys, something maybe lose
    2. check your tooling the bit could be pulling out.
    3. check to see if your ball screw is not shifting on you,
    4. It could be a board issue
    5. When the depth changes is this something that is constant, or is each cut different.
    Mar 2009
    163
    The machine changes depth by around 1mm it also knows its doing this as its reported on the pc.. it isnt mechanical issue. Watch the video and keep eye on z height
    15362
    I watched it, and that is very strange, the way it is doing that, the program you posted is not correct, the arc's don't start and end correctly, so I would go back to the drawing and check that part as well, I tried to run it on a different control, and got part of it to run, but it failed on the arc's Your I and J values are incorrect
    Are you cutting on the line ( cutter center on the line ) or the cutter is offset from the line, what size cutter and what are the dimensions of the pattern
    Mactec54
    Mar 2009
    163
    the code is setup to use absolute arch centers. we do not use any cutter compensation and the tool is centered.
    Jun 2010
    463
    Question what CAD/CAM program are you using...
    Mar 2009
    163
    Master cam/ alma cam/ also the Canadian vendor made code on multicams software, all 3 changes depth on G02 G03 If i only do G01 its fine, also if i do an arch 1mm+ past max depth (max depth active) it doesn't do it.. totally has to be software or firmware /electronic issue on machine or machines workstation.
    Dec 2013
    5717
    What would happen if you added a G17? That might force it into XY moves. If it was always working before and just started acting weird it might be a controller issue.
    M90
    G90
    G71
    G75
    G97 S19500
    G00 T11
    M12
    G00 Z-4.275
    G01 Z-2.921 F1500.
    F1500.
    G17 ( add G17 here )
    G01 X279.4
    G01 X406.4
    G01 X279.4
    G01 X406.4
    G01 X279.4
    G01 X406.4
    G01 X50.8
    G01 X177.8
    G01 X50.8
    G01 X177.8
    G01 X50.8
    G01 X177.8
    G01 X50.8
    M22
    G97 S18000
    G00 T2
    M12
    G00 Z-4.275
    G01 Z0.381 F1200.
    Jim Dawson
    Sandy, Oregon, USA
    Jun 2010
    463
    Just out of curiosity what happens when you run a old successful program?
    M90
    G90
    G71
    G75
    G97 S19500
    G00 T11
    M12
    G00 Z-4.275
    G01 Z-2.921 F1500.
    F1500.
    G01 X279.4
    G01 X406.4
    G01 X279.4
    G01 X406.4
    G01 X279.4
    G01 X406.4
    G01 X50.8
    G01 X177.8
    G01 X50.8
    G01 X177.8
    G01 X50.8
    G01 X177.8
    G01 X50.8
    M22
    G97 S18000
    G00 T2
    M12
    G00 Z-4.275
    G01 Z0.381 F1200.
    Mar 2009
    163
    It doesnt work, the program we noted the issue on was years old run hundreds of times previously.
    Jun 2010
    463
    Just to clarify, this program was old and it has not been reoutput, this program was just in your DNC folder and you have tried to run a previously functioning program.
    Then it is two thngs
    1. DNC has forgotten some setting, if you are using the old JobServer for communications. It can get scrambled in its settings.
    2. You have a control board problem. If this is a M24 K520 board, you options are:
    a. Upgrade to a new control board, I have a customer in Grand Rapids, the quote for upgrade was I believe 19K.
    b. Upgrade to another controller (Mach 3) last choice
    c. Find a older control board, there maybe a few out there. The board will need to be programmed.
    d. Get the board repaired but this is something I have been trying to do for the pass few years now to find someone that can repair.
    QUOTE=diycnc;2119366]It doesnt work, the program we noted the issue on was years old run hundreds of times previously.[/QUOTE]
  1. Multicam 5000
    By brybry-0104 in forum Multicam Machines
    Last Post: 07-03-2015, 12:57 AM
  2. Replies: 5
    Last Post: 05-05-2015, 05:41 PM
  3. Multicam 5000 plunge issue
    By RodneyPierce in forum Multicam Machines
    Last Post: 06-07-2012, 08:44 PM
  4. Multicam 5000
    By scenic cnc9 in forum Multicam Machines
    Last Post: 01-26-2012, 06:20 PM
