586,089 active members*
3,862 visitors online*
    Nov 2017
    Unhappy RDC6332G no connected devices !!
    Hi friends,
    i got a new RDC6332g laser control system. when i switch it on i got the boot screen below & never go till i press ' RESET ' button!!
    when i connect the machine to the laptop & trying to read vendor settings i got ' No devices connected '
    when i try to change the parameters locally from the controller using the master key ' 666888 ' i got the same message ' No devices connected '
    i can't move the axis , fire the beam, read flash disk ... etc
    anyone know how to fix it please?!!
    Nov 2017
    Re: RDC6332G no connected devices !!
    No answers !!
    Aug 2016
    75
    Most laser users on this forum use the newer 6442G or 6442S controller so there probably just aren't that many people here with experience using that controller.
    "80 Watt” 700mm x 500mm Ke Hui 7050 Laser (Similar to the Red Sail)
    Jul 2009
    19
    Any news to this problem?
    I think the problem is with the drivers as the one board is from a customer, one board is new and one board is out of a cupboard.
    I have tried RDWorksV8.01.18 and MetalCutSetUpV1.00.17 with no luck.
    I have also paused my AVG internet security to see if this will make any difference.
    I would really appreciate any help.
  1. external devices connected to a CNC machine
    By sinha_nsit in forum Fanuc
    Last Post: 01-02-2024, 10:21 PM
  2. What is the difference between a Ruida RDC6332G and RDC6442G controller?
    By AdrianPage in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 09-07-2018, 05:42 PM
  3. Granite Devices
    By jnnewton in forum Want To Buy...Need help!
    Last Post: 06-09-2016, 04:59 PM
  4. forget RDC6332G machine perimeter reset password
    By elt342 in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 05-13-2016, 01:42 AM
  5. Replies: 0
    Last Post: 02-16-2016, 11:56 PM
