586,071 active members*
3,859 visitors online*
    Apr 2013
    16
    Machine Vision Alignment
    Hello everyone,
    We have 5 Haas VF2 mills that we use to cut glass (core, chamfer, saw, mill). I have a jury-rigged machine vision system in which the operator finds crosshairs that are laser engraved on the glass to align the part and set his XY home. Has anyone automated their alignment process with a real machine vision system? Ours is currently very time consuming, and I'm looking to speed up the process significantly. Thanks for any help.
    Nick
    Apr 2005
    713
    Re: Machine Vision Alignment
    Do you have spindle probes? You could look at making a setting fixture with a boss or bore in it to probe, that locates at one corner on the edge of the glass if possible. Double sided tape or vacuum cups to hold it in place, then probe. No clue about vision systems. For that you would want to ask on practical machinist .com in the automation category.
  1. LIMAC cnc machine with vision system
    By limacchina in forum Uncategorised WoodWorking Machines
    Last Post: 08-27-2013, 04:40 AM
  2. What is your Vision as machine Shop incharge for next 10 years
    By Khalid in forum MetalWork Discussion
    Last Post: 07-15-2010, 06:01 AM
  3. Replies: 0
    Last Post: 09-22-2009, 10:38 PM
  4. Replies: 0
    Last Post: 09-22-2009, 10:34 PM
