586,112 active members*
3,065 visitors online*
IndustryArena Forum > CAM Software > ArtCam Pro > Gcode file splitting
Results 1 to 8 of 8
    Apr 2006
    512
    Is it possible to split the Gcode via the post processor and how do I do it? I am helping someone out who owns Artcam 2015 r2 but is finding some files are too large for his Chinese router when carving (1.5milllion lines). So I was hoping to split it into 3 files with 500k lines each.
    I am more familiar with vectric post processor where its called tape splitting. Thanks in advance.
    Apr 2005
    3634
    Re: Gcode file splitting
    1.5 million lines of g-code is huge. Is it necessary?
    What's the project? I guess it's art related, but what are you doing to get that many lines of code?
    Free DXF - vectorink.com
    Apr 2006
    512
    Its a finishing path on a very large carving using a small bit /steps.
    May 2017
    1.5milllion lines I think you do not need to split the Gcode file you can Just edit Toolpath configuration from Art file Maybe you have a Small stepover or stepdown You do not need it
    Apr 2006
    512
    I found the solution:-
    Insert the following line to split
    MAX_SEGMENT_LINES = nnnn
    Stepover and stepdown where fine. 1.5 million not to bad for an intricate carving 600 x 900mm. Unless you like sanding.
    Sep 2013
    6
    Quote Originally Posted by bigz1 View Post
    Where do you put that line?
    Apr 2006
    512
    Quote Originally Posted by alchemist1 View Post
    Sorry for the late reply hope this helps:-
    ; G - Code configuration file - with Arc Support
    ; History
    ; Who When What
    ; TM 13/05/99 Written
    ; BEM 20/05/99 Removed line numbers
    ; BEM 21/03/00 Added DESCRIPTION and FILE_EXTENSION fields
    ; BEM 19/06/01 Added support for circular arc output
    ; move to home pos at end instead of 0,0,ZH
    ; bem 07/09/01 Added G17 to define plane for circular arcs
    ;LIAM 06/12/17 Added MAX_SEGMENT_LINES
    DESCRIPTION = "G-Code Arcs (mm) split (*.tap)"
    FILE_EXTENSION = "tap"
    UNITS = MM
    ; Cariage return - line feed at end of each line
    END_OF_LINE = "[13][10]"
    ; Block numbering
    LINE_NUM_START = 0
    LINE_NUM_INCREMENT = 10
    LINE_NUM_MAXIMUM = 999999
    MAX_SEGMENT_LINES = 450000
    Jul 2009
    83
    you can do another way also,take 3 or 4 parts(rectangular boxes should be overlap each other)then select one by one and give machining toolpath same way
  1. Gcode file samples
    By safecnc in forum G-Code Programing
    Last Post: 12-21-2010, 07:38 PM
  2. Rhino problem splitting OBJ file Part1
    By MetropolisCNC in forum Rhino 3D
    Last Post: 06-24-2009, 04:28 AM
  3. Need gcode or dxf file for drilling UHU PCB
    By visky in forum UHU Servo Controllers
    Last Post: 10-07-2008, 08:45 PM
  4. Is there any way to add notes to a gcode file?
    By Anokiernan in forum G-Code Programing
    Last Post: 02-22-2008, 04:11 AM
  5. How to mirror GCode file?
    By anoah in forum Uncategorised CAM Discussion
    Last Post: 07-08-2003, 06:26 PM
