586,072 active members*
4,662 visitors online*
    Oct 2017
    17
    Granite surface plate mounting
    Hey guys, Im in the market for a granite surface plate, and I don't have a level table I can put it on. So I figured I would need a mount for my granite surface. But the mount and granite plate together is pretty expensive. I was wondering if I took three leveling feet turn them upside down and hold the plate with the rubber ends and mount it on my table. I have a very accurate level and I can use the leveling feet to make the surface plate level as well regardless of the table
    Re: Granite surface plate mounting
    Well, three legs is not a smart choice, as the plate is usually very heavy!
    Then putting a vise or an expensive instrument on it, just to have it tip and dump everything on the floor! Wow!!
    Steel legs made from pipe fittings would be the strongest of the cheapest paths to take!
    Widgit
    www.widgitmaster.com
    It's not what you take away, it's what you are left with that counts!
    Feb 2009
    6028
    Depends on the size of the granite....
    My countertops in my kitchen sure don't fall, but I'd be a lot more concerned if a 5x8 starrett was sitting on wood.
    Sent from my SM-T813 using Tapatalk
    Dec 2013
    5717
    Depends on how large the surface plate is. I have a 24x18x4 that sits on the end of my work bench. I built a nice heavy 3/4 inch plywood box that covers it. There is no need to have a surface plate perfectly level unless you are planning to somehow use a level on it to measure parts. It is common to 3 or 5 point mount surface plates, depending on size, but unless you are setting up a metrology lab, I don't see the need on smaller plates. I think your leveling feet idea would work fine, but really overkill.
    Jim Dawson
    Sandy, Oregon, USA
  1. Granite surface plate lathe
    By will gilmore in forum Vertical Mill, Lathe Project Log
    Last Post: 06-13-2018, 08:01 PM
  2. Who uses a granite surface plate for their mills?
    By xander18 in forum Benchtop Machines
    Last Post: 08-25-2011, 12:43 PM
  3. Granite surface plate + water?
    By tikka308 in forum Benchtop Machines
    Last Post: 10-17-2008, 01:44 AM
  4. Cleaning Granite Surface Plate?
    By MrRage in forum Uncategorised MetalWorking Machines
    Last Post: 02-01-2006, 07:09 AM
