Howdy all,
I've recently took my laptop online and sneaky W10 did some updates... Yes, you've guessed it right. I'm having problems with it now.
So, my kflop hardware is all running. I can initialise the machine, home it, manual entry works all right, on screen jog buttons are fine...
The problem arrises as I type some gcode lines in to the G Code Edit Window. Every time I try to run the program, or change the file to another file from the 7 files on the right side menu I get the following error:
Error saving GCode file C:\KMotion433\GCode Programs\From Previous GCode Filenames
Use SaveAs to save to different directory or filename.
Have you guys experienced anything like this? Have you got the fix for the issue?
I would appreciate any help on this matter as I can't figure out what's wrong here. I suspect the problem to be originating from the W10 update.
Cheers
z
