586,069 active members*
3,667 visitors online*
    Nov 2017
    Red face High speed spindle problem in HAAS VF2
    Hi guys,
    I have a 2005 HAAS VF2 3 axis machine here. We bought this machine through an auction around 6 months ago. The machine runs good. Machine is rated to run at 10000rpm. The only problem is, when we put the spindle to more than 5000rpm, the machine shuts the spindle and gives the following messages.
    1) 102 SERVOS OFF
    2) 237 SPINDLE FOLLOWING ERROR( The error between the commanded spindle speed and the actual speed has exceeded the maximum allowable as set in Parameter 184)
    Does anybody knows about this problem?
    Jun 2006
    3063
    Re: High speed spindle problem in HAAS VF2
    You might have better luck in a Haas forum - this one caters to mostly hobby machines made by Charter Oak.
  1. Haas high speed machining hsm
    By allenp in forum Haas Mills
    Last Post: 06-10-2016, 09:54 PM
  2. HAAS VF2-SS High speed machining 15-5.
    By hairball in forum Videos
    Last Post: 09-18-2013, 07:44 PM
  3. Need help! Haas SL-30T lathe high speed not working.
    By arnold wolf in forum Haas Lathes
    Last Post: 07-12-2013, 08:41 PM
  4. Spindle Speed Problem on Haas VF-2!
    By Machineit in forum Haas Mills
    Last Post: 02-29-2012, 09:08 PM
  5. Haas Super VF-4 High speed
    By binzer in forum Haas Mills
    Last Post: 07-25-2007, 09:27 PM
