586,043 active members*
3,696 visitors online*
IndustryArena Forum > CAM Software > Mastercam > can you generate a 2d contour from a 3d model in mastercam x9
    Aug 2011
    77
    so I run into this problem all the time have a 3d model and need to contour the out side of it so I throw a wire frame on it delete the solid model but then have to go around the hole thing clicking each line which is not bad on small parts but have a bow handle to make and has a ton of geometry is there a way to do it like the turn profile ?
    any help would be much appreciated
    Dec 2008
    3109
    Re: can you generate a 2d contour from a 3d model in mastercam x9
    option 1 ... 2 choices
    There are two C-Hooks
    - Create Boundary
    - Silhouette Boundary
    Either is run which then allow you to select a surface or a solid ( or a solid face ), which then places wireframe geometry onto your selected construction depth
    Option 2
    ( not the best for items with angled sides )
    -use "Xform Project" to place lines onto your selected surfaces or solid faces ... this depends on your construction view
    Aug 2011
    77
    so this is the file I am working with I will try to c hooks thanks superman
    Aug 2011
    77
    Quote Originally Posted by redridertwo View Post
    superman
    you saved the day worked great thanks
  1. Replies: 2
    Last Post: 01-07-2015, 10:54 AM
  2. mastercam contour faceted cut
    By fjbart70 in forum Mastercam
    Last Post: 06-28-2011, 09:23 PM
  3. B-spline / NURBS to model linear motion and generate a cam
    By bos10 in forum OpenSource Software
    Last Post: 06-20-2011, 07:36 AM
  4. Contour on Surface. Mastercam 9
    By kram941 in forum Mastercam
    Last Post: 06-25-2009, 05:12 PM
