586,096 active members*
3,588 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Dynomotion/Kflop/Kanalog > How to Merge Init file with external buttons file.
Results 1 to 6 of 6
    Aug 2017
    112
    Hi everyone,
    I need help in merging these 2 c programs attached below.
    One is Initialisation file or Init file for 8 axis Kflop Controller.
    And second is External Buttons.c File for enabling FEED HOLD, CYCLE START, STOP, ESTOP buttons.
    Please help me in merging both into one file, i am new to c and c++ so no idea of merging it. And i don't want to run hit and trials on it because it can damage the board itself.
    Thank You
    AMIT KUMAR
    Regards
    Amit Kumar
    May 2006
    4045
    Re: How to Merge Init file with external buttons file.
    Hi Amit,
    Its not really that hard. Give it a try at least. It is only C code not C++. Wrong code is not likely to damage the board. Post the merged file and we can check it for you.
    You might read:
    KFLOP C Programs - Dynomotion
    Actually the forever loop in your Init program is for enabling/disabling KStep. I don't believe you are using KStep. So that isn't even needed. All you really need to do is to be able to find the loop and replace it. Also add the called functions.
    If you don't have time or can't configure/program your machine yourself we can connect in and help you do this. But for this we charge a fee.
    Regards
    TK
    http://dynomotion.com
    Aug 2017
    112
    Quote Originally Posted by TomKerekes View Post
    Hi Amit,
    You might read:
    Regards
    Thanks tom
    I will give it a try.
    And post here for checking it.
    Sent from my Lenovo K50a40 using Tapatalk
    Regards
    Amit Kumar
    Aug 2017
    112
    Hi Amit,
    You might read:
    Regards
    Hi Tom,
    Thanks for your reply.
    I merged these 2 files accordingly for init button with external buttons file.
    So can you please check it for me if it doesn't have any problems in the code after i run into kmotion board.
    Thank You
    AMIT KUMAR
    Attached Files Attached Files
    Regards
    Amit Kumar
    Jun 2004
    355
    Just a couple minor issues with the merged file.
    You need to add a close bracket just before the DoPCFloat function (add it on line 578).
    And you need to remove one of the close brackets from the end of the file.
    May 2006
    4045
    Hi Amit,
    Looks good except the added functions were pasted inside the main function rather than outside the main function.
    If you would have tried to compile the code the compiler would show the error. Compiling doesn't do anything to the KFLOP board.
    HTH
    Regards
    TK
  1. Merge NC Programs in one NC File
    By zreqi in forum PowerMILL
    Last Post: 03-11-2017, 12:46 PM
  2. FANUC10M LOAD FILE FROM EXTERNAL DIVICE/PC
    By suzukirmz in forum Fanuc
    Last Post: 06-19-2015, 01:14 PM
