586,263 active members*
3,787 visitors online*
Results 1 to 5 of 5
    Jan 2004
    201
    beep too loud
    the beep on my control whenever you push a button just got about twice as loud for no reason i can see.
    is there a setting for this?
    Jul 2005
    340
    if I understand you correctly , the loudness of this beeper you can set up manualy , locate the beeper under the controll pendant ( black wheel ) and rotate it.
    Jan 2004
    201
    I never would have found this, thank you very much.
    I accidentally bumped it when reaching in the tray.
    Is this in the instruction manual?
    Thanks again
    joe v
    Aug 2005
    249
    The beeper is located in the area below the control panel on the top to the right. Rotate the face of the beeper to adjust the volume. Note that the volume is louder when the door is open, that is, if you still have a door. Hope this helps.
    Jeff Lange
    Lightning Tool & Manufacturing, Inc.
    Aug 2005
    249
    Quote Originally Posted by 1ctoolfool View Post
    Thanks again
    joe v
    See my response below. Yes it is in the manual. Should be in the area that has diagrams of the control panel with descriptions and functions of the individual items of the control panel.
    Jeff Lange
  1. Silencing a loud air compressor
    By wisp in forum Mechanical Calculations/Engineering Design
    Last Post: 08-16-2010, 10:14 PM
  2. V2XT Head Rebuilt= runs hot & loud
    By v488 in forum Bridgeport / Hardinge Mills
    Last Post: 06-21-2006, 01:35 PM
  3. How Loud is a router?
    By CNC Brute in forum DIY CNC Router Table Machines
    Last Post: 12-11-2003, 02:25 AM
  4. Thinking out loud
    By kong in forum DNC Problems and Solutions
    Last Post: 04-29-2003, 02:58 PM
