586,399 active members*
3,091 visitors online*
IndustryArena Forum > CNC Electronics > Spindles / VFD > NEW DIY CNC WOOD ROUTER SPINDLE HOOKUP
    Dec 2013
    8
    Unhappy NEW DIY CNC WOOD ROUTER SPINDLE HOOKUP
    Hello Everyone,
    First time here. I have been building a new CNC wood router for my home shop. It is approx. 5' by 8.5' I have used rack and pinion on X and Y axis's and a ballscrew on the Z axis. All axis's are moved by Teknic Clearpath SD motors. The spindle is a UGRA air cooled spindle motor with a DELTA M vfd. I am using Windows 7 PRO, MACH 3 and a C23 board with smoothstepper with Ethernet connection.
    Now for my trouble....I cannot figure out the hookup for the VFD to run the spindle. All parameters at set in the VFD for using 0-10 volt AVI and GRD. The NO relay for MO and GRD, However I never get the 0-10 volt out of the board to command the VFD. I have Configured the Mach 3 Ports and Pins / Sindle setup to Output #1 for both M3 and M4. Also have turned on the outputs for port 1 and pins 14 (0-10 volt output pin) and 16 (NO relay) but no output out of the board to run the VFD. I have tried everything. I really need some help here. Thank You very much in advance.
    15362
    Re: NEW DIY CNC WOOD ROUTER SPINDLE HOOKUP
    Quote Originally Posted by forbri40 View Post
    Hello Everyone,
    Have you followed the C23 manual, it uses step/dir signal to create the 0-10 out put, the board needs 12v also, check the smooth stepper setup also
    You will have to have the 0-10v working at the board output, plus one of the relays to switch the M0 and GND to make it work, plus the correct Parameter set in the VFD
    Mactec54
  1. Which Wood router is best to use as a spindle?
    By i_am_joe in forum Spindles / VFD
    Last Post: 02-16-2015, 06:23 AM
  2. Replies: 0
    Last Post: 09-19-2012, 05:03 AM
  3. Spindle Choose for CNC Wood Router
    By omnicnc in forum Omni CNC
    Last Post: 09-14-2012, 03:50 AM
  4. 4.5KW spindle motor CNC router for wood
    By SPC-laser in forum News Announcements
    Last Post: 08-15-2012, 06:41 AM
  5. wood router and spindle control
    By eloid in forum CNC Wood Router Project Log
    Last Post: 02-21-2007, 11:39 PM
