586,075 active members*
4,515 visitors online*
IndustryArena Forum > CAM Software > Autodesk CAM > Help with Toolpaths in Fusion 360
    Mar 2017
    181
    Newbie here...
    I'm starting to get the hang of designing stuff in Fusion 360. Granted they are all simple designs but hey, they're mine & their done.
    Well, thought I'd try to output one to G-Code and just maybe cut it. Started with a simple Hold Down Knob but I can do nothing with it!
    I try to Generate A Toolpath and I get an error message.....NO OPERATION NEEDS TO BE GENERATED
    I try to Post Process and get the error message.....NO VALID TOOLPATH
    Can anyone suggest a YouTube I can watch or a Paid Tutorial that I can follow? Is there a Tutor anywhere near Charlotte, NC that I could hire?
    Any suggestions would be appreciated.
    Attached Thumbnails Attached Thumbnails Post Process.jpg   Generate Toolpath.jpg
    Nov 2014
    724
    Re: Help with Toolpaths in Fusion 360
    Your setup is complete but you've not specified any tool profiles. How are you going to hold the part down to the table? You'll need to allow for that. What do you want to do with it now? Bore the center hole? Choose 2D, Bore, pick the appropriate tool/bit, and specify the parameters for the cut - geometry, passes, linking, etc., and when you close that dialogue box it should generate a toolpath. Then go to 2D or 3D pocket clearing to cut the recesses around the protrusion and finally choose 2D contour to cut the outer profile of the knob. Does that help?
    David
    David
    Romans 3:23
    Etsy shop opened 12/1/17 - CurlyWoodShop
    Jun 2010
    27
    In some ways, the CAM part of the workflow is harder than the CAD design work. Its an art onto itself, and a whole new learning curve.
    there are tons of fusion tutorials online and youtube.
    Autodesk has many;
    https://www.youtube.com/results?sear...esk+fusion+cam
    John Saunders at NYC CNC has alot of good ones too. he does a new one every Friday.
    https://www.youtube.com/results?sear...friday+nyc+cnc
    Mar 2017
    181
    Yeah, well I'm trying to understand but it's late for me. I had a massive stroke and my brain goes to sleep when it's good and ready and it's ready.
    As you can tell I've never done this before so it's kinda "Greek to me" but thanks to you I know have an idea of what to do.
    I'll try it again tomorrow...and thanks again!
    Jun 2010
    27
    There is alot to lean with all this CNC stuff, and each one seems harder than the last...build or buy a machine, learn software to CAD parts, learn software to CAM parts, learn machining processes (feeds/speeds etc), learn machine control software...blah blah blah.
    Good luck man!!!
    Sorry 'bout your health issues.
  1. Problems with Fusion 360 toolpaths
    By Andrew22 in forum Autodesk CAM
    Last Post: 05-26-2017, 03:33 AM
  2. Replies: 23
    Last Post: 10-31-2014, 03:26 PM
  3. 3D Toolpaths
    By coykiesaol in forum Jewelry Design Software
    Last Post: 11-09-2010, 08:21 AM
  4. Can anyone help me with toolpaths for this???
    By cloverfield333 in forum Mastercam
    Last Post: 12-21-2009, 04:21 PM
  5. OMG all the toolpaths!!!
    By dbtoutfit in forum Uncategorised CAM Discussion
    Last Post: 06-18-2006, 06:42 PM
