586,119 active members*
3,683 visitors online*
IndustryArena Forum > CAM Software > Mastercam > Can mastercam x level 3
Results 1 to 3 of 3
    Oct 2005
    40
    I have a question can mastercam x level 3 do 4th axis rotary contouring and indexing work? I have a vertical mill with a rotary table and I am thinking of picking up a copy of Rotary contouring and indexing from Tips for manufacturing along with there other video but I am not sure if it will help me with level 3 I know mastercam has a complex 4th and 5th axis add-on which I don’t have.
    Mar 2006
    1013
    Level 1 will do indexing for vertical and horizontal.
    Rotary contouring might have been moved up to the Level 3 + 5 axis add-on.
    You can also do some rotary contouring with Level1 by doing the flat layout toolpath and Mastercam can "wrap it" around the rotary axis. This is also good for barrel cams and cutting slots on the outside of a cylinder.
    So the only thing you need the 5X add-on for is 3D surface rotary machining. Not really that common. Since you can 3D surface machine one face, rotate and 3D surface machine another face, if you really need to to something like that.
    Mike Mattera
    Tips For Manufacturing Training CD's, DVD's for Mastercam, SolidWorks, Inventor, G-Code Training & More
    http://www.tipsforcadcam.com
    Apr 2003
    3578
    Mike still like in the past 4th axis sub and indexing still Level 1.
    Cadcam
    Software and hardware sales, contract Programming and Consultant , Cad-Cam Instructor .
  1. Level 1, 2, or 3
    By rodneydeeeee in forum Dolphin CAD/CAM
    Last Post: 02-13-2007, 05:44 PM
  2. Taking it to the next level
    By sploo in forum Commercial CNC Wood Routers
    Last Post: 01-21-2007, 09:58 PM
  3. Need to know the best way to level a machine
    By cncadmin in forum DIY CNC Router Table Machines
    Last Post: 10-17-2006, 03:58 PM
  4. level and hangup
    By bilyjimbob in forum DIY CNC Router Table Machines
    Last Post: 10-25-2003, 10:52 PM
