586,108 active members*
3,071 visitors online*
Results 1 to 3 of 3
    Oct 2010
    670
    Shimming the gang tooling
    So folks, setting up the Slant Pro and everything is going pretty good. Setting up the gang tools and have run into a little bit of a problem (I think). In order to get my drills lined up with the centerline of the stock. I'm having to put .084" worth of shims in there. Oddly enough, there was a pack of 6 shims with the gang tool starter kit that each equal .042". So I guess my real question is, do you shim the riser block or the tool block. Seems that if you shim the tool block it kind of defeats the purpose of making them hot swapable.....
    Thoughts?
    Awall
    The Body Armor Dude - Andrew
    Mar 2008
    82
    Re: Shimming the gang tooling
    I shimmed the riser block.
    I shimmed the tool block...... they realized it took all of my shims because it was so low..... and wished I had just shimmed the riser block.
    EDIT: spelling
  1. Whats your procedure for aligning and shimming gang tooling?
    By s2jesse in forum Tormach Slant Lathe
    Last Post: 06-17-2016, 12:45 AM
  2. tramming by shimming head vs shimming table
    By amish_rabbi in forum Novakon
    Last Post: 11-26-2014, 09:37 PM
  3. Gang tooling help..
    By roger_e in forum Vertical Mill, Lathe Project Log
    Last Post: 01-30-2010, 01:03 AM
  4. Gang tooling
    By lcarrudajr in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 05-08-2009, 10:47 PM
  5. Shimming lathe tooling?
    By SRT Mike in forum Uncategorised MetalWorking Machines
    Last Post: 08-08-2007, 10:34 AM
