586,070 active members*
3,592 visitors online*
Results 1 to 5 of 5
    Dec 2005
    74
    HAAS TL_3 varistor codes
    I need all varistors code for change, please. The first for right position is fire and i can´t read the correct numbers.
    Regards,
    Alain
    Mar 2007
    2083
    Re: HAAS TL_3 varistor codes
    as no one with a HAAS TL_3 has replied
    do you have the maintenance manual with the circuit diagrams showing the connections to the varistors ??
    going by your photo it looks like you have
    EPCOS S20 K250 in positions VR1 & VR4
    and what looks like
    S20 K460 in positions VR2 , VR3, VR5 and VR6
    PDF EPCOS data sheet :-
    Attachment 379446
    after a quick web search
    in the UK , http://uk.farnell.com has them
    http://uk.farnell.com/epcos/b72220s0...ngdom%2Fsearch
    in the US
    Mouser Electronics
    https://www2.mouser.com/Search/Refin...yword=s20+k460
    John
    Dec 2005
    74
    Thank you so mucho my friend, is correct.
    Regards,
    Alain
    Dec 2005
    74
    Hi John,
    I was looking the board and the order varistor is not the same. Attached the diagram.
    Mar 2007
    2083
    Hi Alain
    obviously the photo did not show me enough detail !!!
    I have had a look at the HAAS web site but they don't appear to make the circuit details of the PCB's available
    assuming no other damage has been done ( like fuses or PCB tracks blown )
    I would expect you will measure about
    230 to 240 V AC across the S20 K250 varistors
    and 420 to 440V AC across the S20 K460 varistors
    so you should be able to workout what device was destroyed
    by measuring across the PCB terminals
    the S20 indicates the varistor's diameter
    and the 3 digits after the K is the Max. AC operating voltage
    what does the under side of the burnt terminals look like ??
    be care full removing the wire ends not to pull out the Via's (plated through holes)
    or peel the copper tracks of the board
    John
  1. List of Haas G codes?
    By rawen2 in forum Haas Mills
    Last Post: 10-29-2012, 03:37 AM
  2. Varistor for Anilam Crusader M
    By schmepe in forum CNC Machine Related Electronics
    Last Post: 06-26-2009, 11:05 PM
  3. Haas Quick Codes
    By MetalMolder in forum Haas Mills
    Last Post: 04-28-2008, 02:16 AM
  4. Nc PLot and Haas G71 G72 codes
    By PaintItBlue in forum NCPlot G-Code editor / backplotter
    Last Post: 12-08-2007, 07:42 PM
  5. Haas HL-4 ERROR Codes
    By altcan in forum Haas Mills
    Last Post: 09-13-2005, 03:33 PM
