586,036 active members*
3,844 visitors online*
IndustryArena Forum > CNC Electronics > CNC Machine Related Electronics > Granite VSD-e drive flashing Red and Blue
    Nov 2007
    66
    I have a homemade router with a Centipede setup from KSI labs. 3 axis and I get a blue steady light on two of the drives, but the y drive has flashing blue and red according to the manual, it means that the HV is either too high or too low. A voltage check indicates that I am getting 144 VDC to all three drives. What could be the cause. I have plugged in the machine and sometimes I get all blue lights on all three drives and it will perform a program, but most of the time I get the y axis flashing lights. Does anyone know if Sergey at KSI labs is still around? Please help, Robert Brown.
    Nov 2007
    66
    Re: Granite VSD-e drive flashing Red and Blue
    OK, everything is allright now by installing another drive. Checked the parameters with GDtool and then fired it up, all blue lights, so it was a bad drive, and also it took care of my Estop problems. I guess the system automatically goes into Estop with a questionable drive, so thanks everyone, Bob.
  1. Replies: 2
    Last Post: 02-07-2019, 03:13 PM
  2. Antek Power supply and Granite drive issue
    By Dr.Nos in forum CNC Machine Related Electronics
    Last Post: 09-27-2013, 01:15 AM
  3. Blue Screen mostly black instead of blue
    By turmite in forum Screen Layouts, Post Processors & Misc
    Last Post: 07-01-2013, 10:27 PM
  4. Granite Drive with Windows 7 64Bit
    By speedydumpster in forum CNC Machine Related Electronics
    Last Post: 07-06-2011, 11:47 PM
  5. HELP ! Acramatic Big Blue Tape Drive Failure
    By Mark Pelnar in forum Cincinnati CNC
    Last Post: 03-26-2009, 12:48 PM
