586,042 active members*
3,884 visitors online*
    Jan 2009
    33
    FRO not working
    I bought a new CNCRP Pro 4896, installed the version of Mach3 they recommended. Also used their xml file.. I also installed an XHC pendant..
    My problem is, when I use the arrow keys to jog, it moves about .028 (different each time).. on the pendant, it moves about .020 but will come back to the same place if I turn the wheel back.. I turned it to 2% for .001 but it still moves .020+ each time. When I try to adjust the FRO, doesn't matter if it all the way down or up, nothing changes in the speed of movement..
    Is there some way to adjust this?
    Re: FRO not working
    Sounds like you are in step mode.
  1. Setting drills, ID tools and back working/end working tools
    By jonathan2jones in forum CNC Swiss Screw Machines
    Last Post: 04-22-2017, 01:11 AM
  2. What is the difference between wood working and metal working routers?
    By LaughingJaguar in forum Joes CNC Model 2006
    Last Post: 10-17-2016, 07:29 PM
  3. Switch view between machine working enveloppe and job not working?
    By skillalot in forum Screen Layouts, Post Processors & Misc
    Last Post: 08-10-2015, 03:55 PM
  4. Got it all working
    By borne2fly in forum EZ-CAM Solutions
    Last Post: 04-06-2013, 12:32 AM
  5. G96 not working as it should
    By mbpp in forum G-Code Programing
    Last Post: 06-14-2009, 01:51 PM
