586,080 active members*
3,539 visitors online*
IndustryArena Forum > CAM Software > BobCad-Cam > Machining a STP file in Bobcad Ver30 build 2553. Not happening?
Page 2 of 2 12
Results 21 to 28 of 28
  1. #21
    Aug 2015
    28
    Re: Machining a STP file in Bobcad Ver30 build 2553. Not happening?
    thanks I'm looking for a little more detail. I am coming along fine with the stl I have a;ready...I can buy one in an stp format but the detail is not there. I've been building bikes sense 1978, This is going on the bike representing my shop. now that I have the time and resources, I'm going to build a working file with as much detail as possible... Thanks again....
    The end result is directly connected to the effort applied
  2. #22
    Aug 2015
    28
    Re: Machining a STl file in Bobcad Ver30 build 2553. Not happening?
    Quote Originally Posted by magicniner View Post
    Freecad can be used to convert .stl to a solid by importing the .stl in the mesh workspace then in the part workspace create shape from mesh then saving out in the format of your choice,
    - Nick
    That's what I'm looking for damn right, does the free in freecad actually mean its free?
  3. #23
    Apr 2009
    3376
    ok,,I guess your direction now is FreeCad ?
    I also am thinking or assuming that you are using 4th axis ?
    If that is correct,I am out,,,Nick and Burr would be better to help you
  4. #24
    Quote Originally Posted by JohnHennessy View Post
    Yes, it's completely free, I only use it as a tool for converting .stl meshes into solids I can use in BobCAD.
  5. #25
    May 2013
    701
    Good to know
    A while back was there some conversation about the mesh having to be water tight if so does it do a good job at that?
  6. #26
    Quote Originally Posted by RAF. View Post
    Good to know
    I don't create meshes in FreeCad, I use BobCAD V25 plus an old, free version of Netfabb (from before Autodesk bought the product and which can still be found on GitHub) to clean up any problem areas.
  7. #27
    Aug 2015
    28
    I'm posting this in hopes someone with the same problem can over come it by using my labor so you wont have to...... The answer to my problem was to use "emboise from component" in bobart .....
  8. #28
    Apr 2009
    3376
    Cool,,,,love to see the finished product
Page 2 of 2 12
  1. New to bobcad v22 help opening file?
    By Coolster in forum BobCad-Cam
    Last Post: 07-02-2018, 09:01 AM
  2. Convert bobcad file to dxf or eps
    By kzey in forum BobCad-Cam
    Last Post: 09-11-2017, 06:06 PM
  3. Tool file. (Bobcad V25)
    By Gallchobhair in forum BobCad-Cam
    Last Post: 06-05-2014, 04:45 PM
  4. How do I get a DXF file in to Bobcad?
    By Just_sawing in forum BobCad-Cam
    Last Post: 09-25-2013, 12:21 AM
  5. printing to file in bobcad
    By oxford in forum BobCad-Cam
    Last Post: 12-26-2008, 09:11 PM
