586,069 active members*
3,410 visitors online*
IndustryArena Forum > CNC Electronics > CNC Machine Related Electronics > Need serious help. Runaway axis on power up.
Page 2 of 2 12
Results 21 to 22 of 22
  1. #21
    Nov 2007
    66
    Re: Need serious help. Runaway axis on power up.
    Remember I said "so far", well I go out and ran a successful program, jogs worked , everything worked. I go out an hour later and after Mach3 is booted tried to plug the HV in and nothing but sparks at the plug. I found two loose connections on one cap. re crimped them, isolated the HV from the system and then plugged it in to a different 20 amp circuit and it didn't pop the breaker, also fired up the computer and that is OK. At first I had everything on one 20 amp breaker and I am thinking with the loose wires and the fact that it was on one breaker the surge of the HV was too much, so when the caps dissipate, I am going to try it again and see what happens. I will let you know. I guess that I have to be smarter than the machine, and that is a challenge for me. Bob.
  2. #22
    Nov 2007
    66
    Everything is fine for now, must have been overloading one plug and loose wires on the caps, ok for now, Bob.
Page 2 of 2 12
  1. X-AXIS runaway
    By cnctoolman in forum Tree
    Last Post: 02-13-2017, 08:53 PM
  2. CNC88 - Runaway Y axis
    By mbam in forum Fadal
    Last Post: 11-01-2011, 04:42 PM
  3. Y axis runaway
    By damelman in forum CNC Machine Related Electronics
    Last Post: 11-10-2009, 01:18 PM
  4. Help, Z axis runaway
    By Nicholas in forum DNC Problems and Solutions
    Last Post: 06-18-2007, 06:08 AM
  5. a.g.e. 3, z axis runaway condition
    By lesnesman in forum Bridgeport / Hardinge Mills
    Last Post: 11-27-2005, 03:36 AM
